SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Make sure you are using BUNN brand cupcake filters, not the shorter-sided generic variety. Also, inquire with BUNN about an optional attachment for some models that will slow down the rate of water flow. Lastly, ensure that you are not over-filling the basket with grinds. There is an upper limit to how much a coffeemaker will hold, and some people try to compensate for weak coffee by adding too much.
SOURCE: My cuisinart cofee maker is clogged. Water goes
I have the same problem. I did not seat the pot properly below the grounds, the grounds and hot water overflowed into the water tank and clogged the machine.
I have tried to rinse the unit numerous times, have used white vinegar instead of clr, but to no avail.
I'm afraid coffee grounds are clogging the inlet pipe at the bottom of the water tank and all it does is generate steam.
There is no way to disassemble the unit and clean it so I'm now faced with buying a new unit.
SOURCE: Water and coffee spilling from Filter Basket onto counter?
We used to have the same problem! try a better brand of coffee filter! It worked for us? Also make sure that the filters are not doubled up!
SOURCE: searching for a replacement filter basket for a
I bought that coffee maker at a yard sale and it doesn't work, so you can have the basket if you'd like.
SOURCE: Black & Decker DCM1350 Coffee maker
coffee pot will not turn on...is there an internal fuse worked find the last time it was used
