Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
Posted on Nov 04, 2009
Trying to connect to my pc via active sync and use it with Tool Hound. this scanner was previously used with another application.
Anonymous
Level 1:
  • Contributor 47 Answers
  • Posted on Nov 04, 2009
Anonymous
Contributor
Level 1:
Answers
47
Questions
0
Helped
39909
Points
64
You will need an appropriate application for Tool Hound. They have a client for your gun. You will have to contact Tool Hound. Your previous application on the gun is looking for it's host. It won't work until you get your Tool Hound rep involved.
Bill Barcode
5helpful
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
2answers
When the DataWedge 2.0 is launched, an Error "cannot set scan parameters 00000000" appears and scanner does not function. Was running just fine. MC7094. Scanning is working fine in another...
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
1helpful
HOW TO CONNECT THE HTC P3300 MOBILE IN MY LAPTOP WHICH SOFTWARE ARE USR
You can use this tool to to be able to synchronized the phone to your computer.
Download this stuff : MS ACTIVE SYNC
This application can transfer all personal data from phone to computer or vice-versa.
* just download the application
* install and run it after
* plug-in your mobile to your pc using a usb data cable
* some drivers will be install and wait until the phone is recognized or sync is in progress.
enjoy using the features...
ScanAllPro starts, chose the scanner shows the error: scanner is not connected or another application is using it. but no application is used at this moment. and the test with document scanning by...
Hi,Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.Specify which driver is used for the scanner, the TWAIN or ISIS/VRS driver. When a scanner is no longer connected to a USB port to which it was previously connected, this option checks if any scanner of the same model has been connected to the other USB port. If the same model is found there, this option automatically switches to the other port and inherits the settings of the same model.
* This option will not be available, however, if a different model has been connected to the port where the scanner was previously connected. * Disable the settings when you want to connect more than one scanner of the same model to your computer.
Thanks,
ScanCare
2answers
First time connection?
You need to have active sync in your computer to connect pda to computer
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
Download Active sync from link and install to Pc .you can connect pda to computer now
HP iPAQ 110 will not active sync
no operating systems stated,
windows 10? what?
why would a battery this old be good, if was, its like world record.
buy a new battery ,better upgrade to smart phone.
sync
but the HP end and the Microsoft end have to have compatible and working drivers. to work.
the 110 is dead product at HP
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544497
your only hope is talking to Microsoft now,
see if they support it, my guess w10 does not
how far back , support software drivers ended, ask MS.
looks like (hard to track) w7 is last OS supported.
i see scalpers selling drivers now, for this old product.
good luck with them,,,
try asking on a real HP forum
other asked this vast times, and the answers are dead correct.
http://h30434.www3.hp.com/t5/Calculators/Synchronization-involving-HP-iPAQ-110-and-Windows-8-PC/td-p/5078151
excerpted
Unfortunately, WMDC is not compatible with Windows 8 and you will not be able to sync your Outlook related data to your iPAQ. There is no expectation that Microsoft has any plans to update WMDC to make it compatible.
You may be able to use a third party paid application to sync the data, like Companion Link or Akruto Sync.
Connecting to pc
make sure you've loaded the software the phone came with onto the host pc (fully loaded it, and go through the "configuration" routine it asks you to complete after installing the activesync software). That should fix your problem. Incidentally tho, i've connected my phone via usb cable to pc's that did NOT have the active sync software installed, and those pc's still recognized the phone as a removable drive (without the syncing capability). You can still install applications and syncronize files manually so long as the host pc sees it as a removable drive tho (although it takes a tad bit more technical knowledge, such as file paths and the like)
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Top Zebra Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
