Health & Beauty Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WILL INDICATE FULL CHARGE AND THEN FAIL AFTER A SHORT PERIOD OF USE , POWER INDICATOR LIGHTS WILL 'RUN UP AND DOWN' THEN GO TO LAST BAR AND FLASH, THEN SCOOTER STOPS. SWITCHING OFF WILL RESTORE LIGHTS BUT THEN AFTER A FEW YARDS THE SAME PROBLEM REOCCURS. I HAV E BOUGHT NEW BATTERIES BUT PROBLEM STILL EXISTS.
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on Nov 06, 2009
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
41074
Points
147
It sounds like a battery issue. Have the batteries load tested.
Ion Block Rocker Plus Battery charge indicator light on with three bars not flashing , never did flash. Cant get any thing to work no sound no display except charge indicator light.
Please first check that the volume is turned up on your device. Then, I would advised changing the power source .
If still no sound, please power down your device for 10 minutes before turning on again testing the sound. If all else fails, please view the troubleshooting section of the device manual next.
Thank you.
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
How long does charge last, want to charge before giving as a gift
charge to at least 50%. (For storage purposes, so that the battery won't get messed up).
You can tell this by checking the battery indicator (bars, icon or percentage) periodically. If it shows 50% or an icon that shows a battery half-full.
sorry if this was confusing, as I am tired.
Dec 04, 2013 • Cameras
Power supply wiring diagram
The flashing blue light indicates the battery is nearing full charge. If the light is continuing to blink when you reach 100%, I believe this is an indication that the battery is beginning to fail and will not hold a full charge.
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
2helpful
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
4helpful
Dell XPS M1330 PC - battery not detected
The error code 0146 and the battery are two separate problems. First the battery problem is simple, it's bad and needs replaced. It being bad can refer to a developed short, a fail safe kicked in, or it's simply worn out. It is a battery after all, ad they don't last forever, the more you use them the quicker they wear out. A bad battery causing an issue is vary common with Dell machines, and a false battery reading with a failing battery is also common. The orange flashing battery light is the indicator that the battery isn't working properly, either by fail safe or wear.
The error code 0146 Is from the short test on the hard drive and indicates the a sector is going bad, and eventually the hard drive is going to fail. At this point, your hard drive may last days, or months. Either way, I suggest that you back up all important data, and purchase a new hard drive for the imminent failure. You might even go ahead and set it up, this way you'll be prepared when it does go, and you won't have any downtime.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
