I also having the same problem while updating my phone get restarting. the only way is to update the phones software will solve my problem. u can also check the nokia website for updating the software details.........
Problem for Nokia 3110 Cellular Phone My nokia 3110c music player updates upto 100% but
My nokia 3110c music player updates upto 100% but then it displays "No
music files found" although my memory card is full of song.
Solution: Avoid shifting different downloaded themes on your Nokia 3110 c. Shifting more often may corrupt your music player and can not detect your music files on your phone... Update your phone software using the nokia Updater software... But improper updating may damage your cellphone... If u are not confident enough to have the risk try downloading the KD player software.... copy it to your memory card.... take a while to explore it in your phone.... and YOU CAN PLAY YOUR MUSIC FILES....
Hi! I used the Nokia Software Suite Music Manager to copy music files from my PC to the 2gb MicroSD card in the phone. First time there was no problem but after 2 weeks i try again to add 2 songs, after I add them when I try to start music player none of this files(or the old ones) can be found by music player!I try to format the card, or reset the phone to the factory sett. but nothing work, I also try to remove the card and play music from phone memory but again nothing. If I try to play music by opening only one file from galery then it works but Music player can't find any song.Please advise how to use the Music Player!
SOURCE: my nokia 3110c music player updates upto 100% but
Hi, it always happen when the memory card is not reading n the phone,either is not inserted properly.
Switch off the phone and re-insert the memory card and see if it will work.
After re-inserting the memory card,if not result yet, you will have to test memory card with another phone to see if the memory card is still function properly .If the memory card functions on another phone,that means the memory card slot where you fixing the memory card in damaged and will need to be replaced.
Take care.
contact service prolamb
Hey Guys!!
I've just found the solution of the problem!
Problem is : Some of the mp3 files are "READ ONLY"
All you got to do is delete those files which are read only!
PROBLEM SOLVED!
100% Checked!
Hey Guys!!
PROBLEM SOLVED!
100% Checked!
Hey Guys!!
PROBLEM SOLVED!
100% Checked!
