Washing Machines Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE profile front loading washer I bought in 2001. Model # WPXH214A0WW. I just replaced the timer because it stops at a couple different times in any given cycle. I thought the time cogs were worn out but that wasn't it. It looks like it doesn't want the rinse cycles to work but it does originally fill. We thought it was the cold water only but looks like even if you do the warm/warm cycle it still stalls during the cycle. It is getting power to the 'mixer' for lack of a better description. It is the part that the hot and cold hoses come in to. I believe that is where it isn't letting the rinse water in each time it should.
  • tomsethfamil Nov 04, 2009
    As we said - it appeared to be the cold water rinse but it also stalls during the warm water rinse. We just replaced the timer and it wasn't that part. Any other ideas?
    Part 2 comment - sorry Milten I hit send too early. The cold doesn't work even to start a wash but it appears that when it gets to rinse cycle, it doesn't matter whether it's on cold or warm rinse. Does that have to do with the ability for that water 'mixer' thing in the back of the machine not working properly? What is the name of that part? We tested and it has power to that part. Water appears to be coming in from the back.
    Thanks
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2971277
Points
24702
HI. Your assessment is correct. The inlet assembly should be inspected for damage. Follow the procedure below to correct this issue.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Anonymous
Level 3:
President:
  • Master 1,304 Answers
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367322
Points
3700
More than likely it is your cold,
the warm warm could be the tip off
try a cold water wash
this particular model the timer is what controls
the mixer valve
  • Anonymous Nov 04, 2009
    If i am reading it correctly, the cold is not working, even on a cold wash cold rinse,
    where the water comes in is called the mixing valve.
    there should be two coils, cold and hot,,,,
    if you have voltage to the valve coil, do you have resistance or continuity
    it sounds like cold is not opening,,,
    and yes if cold does not work properly it will cause the conditions you speak of.....
    try to ohm out the solonoid on the water valve,
    you should read cointinuity......
    if thats not true the coil is your problem,,, you can have voltage there , but if the coils is burnt, they usually burn open,,,,
    pull the machine out take out the 16 screws in the back panal,
    on the bottom to the left you should see a control board
    inspect that board for burnning and or a bad fuse
    just had a hunch
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
GE front loader Machine continuously fills and drains washer without washing clothes. Model #WPXH214A0WW
Either belt (worn or broken, if belt driven) or main motor. Unplug unit, remove back access panel. Inspect mechanics for problems.
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
1helpful
My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
2answers
GE profile Clothes washer
SOUNDS LIKE THE TIMER IS GOIN OUT, NOT TO SURE, BUT SOUNDS LIKE THE CONTACTS ON THE TIMER IS ON ITS LAST LEG, GET THE MODEL NUMBER AND SERIAL NUMBER AND SOURCE AROUND FOR A REPLACEMENT TIMER............
ITS REALLY EASY TO REPLACE..........
GOOD LUCK........
Top Washing Machines Experts
john h
