A few days ago unit stuck mid-cycle. It's not cycled since. Manually turning dial causes correct response from unit but dial will not turn on it's own. Is there a reset or is this something else?
You should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
