Toshiba Satellite A105-S4334 Notebook Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install toshiba satellite A105 S4334 memory
I boufht a 2GB Memory Ram card and dont know how to install it
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Nov 04, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368897
Points
33650
  • Bud Martin
    Bud Martin Nov 04, 2009
    note number 3 shows the two memory sticks.
Where is the memory located in a Toshiba Satellite A105-S4334 laptop?
Hi
The memory is normally located underneath the laptop
normally a oblong cover with 2 screws
just undo the screws and remove the plastic plate
3answers
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
My toshiba A100 satellite will not let me install Company of Hero's. It keeps saying that I do not have enough physical memory. I do not have any other large programs on my computer and can not find a way...
How much RAM is installed in your laptop? Most laptops can take up to 2GB which is enough for most any games. Find your Owners Manual (on your hard drive) to find directions to find the memory's location. I have a Toshiba Satellite A105 and the memory is behind a panel hedld in place by a Philips screw labeled "4" in a circle, if that is any help.
2answers
I have no sound card. The sound was working fine since I got the compuer, and now it doesn't work.
Go to toshiba's website, then look up your model " Satellite A105-S4334 " > Look for drivers/download section > Look for sound card driver > Install and restart your laptop and you should be working.
Yup same problem here..
I give you some possibilities.
1. Could be dirty contact for your memory card, try to take out the battery and no power supply attached and shut it down completely, then clean the memory edge connector with a clean soft eraser. And be sure to drain your hands with static. Then reseat it back into its place. Or the memory card or actually faulty using an spare ram to check it.
2. This can be also monitor problem, try using secondary monitor and run it to dual monitor.
3. There's some component giving up in your system, usually hard drive or cdrom. This cause hanging and shut off of your unit also. Try disenganging one at a time to find the fault. And boot using usb flash drive if you can.
This is my simple and first way fix. goodluck
How do you install ram in a toshiba a105-s4344 laptop
I take it that you already have the correct RAM you need. Wiith that, power off your notebook, unplug it, turn it over and your will see the larg cover closer to the right of the notebook. Unscrew the screw to release the memory cover and place it to the side. Be carefull with static when handling your memory card, install the card into any open slot in your notebook. (The memory card will go in the slot at a 40 degree angle and then 'snap' down into place. Replace the memory cover (the large piece you took off at the begininig.) power up you notebook and the new memory should be registered and ready for use. Good Luck.
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    9answers
    Toshiba a105-s101 memory install boot issue
    Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
    BPCS
    Top Toshiba Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
