Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1099
Points
I'm running into the same problem. I have the Kohler Vinnata 691 kitchen faucet. I have replaced the cartridge in the handle at the base of the faucet and am still finding water leakage as before. Are there other parts I need to check?
john h
Level 3:
Top Expert:
  • Moen Master 29,494 Answers
  • Posted on Nov 04, 2009
john h
Moen Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7547055
Points
193449
Turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
1helpful
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
2helpful
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
How do I open the body of K-10430 apart to replace the valve cartridge kit that's leaking
The handle has a allen set screw loosen that until the handle comes off then the bonnet nut will unscrew revealing the bonnet cap and washer the cartridge should be under that most kohler's require a special tool to remove cartridge(turn water to faucet off prior to working on faucet,also note how everything is removed it needs to be replaced in same order especially the cartridge,also you should use plumbers grease to coat all seal when replacing everything).
I have a Kohler Fairfax 12176 kitchen faucet and it is about 4 years old. It is starting to leak water out of the spout for a split second on occasion when you turn the water on. As time goes on, it is...
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
Call Kohler if you need more info.
2helpful
How remove it to fix a leak
Remove top handle and lock nut and remove plastic cartridge buy the cartridge it has detailed instructions better yet call 1-800-4-KOHLER and they will mail you a free replacement
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
