BOARD RUNS REAL SLOW - Computers & Internet
Posted by tigerforwork on
  • tigerforwork Nov 04, 2009
    ok it is running 1 gig ram when i try and connect more than one hard drive on the secondarty channel it wont find it to be exact
  • Art Ellison
    Art Ellison May 11, 2010
    What exactly is your problem? If you tell us just what is running slowly, perhaps we can help.
Roshan Rijal
    Sergeant:
  • 361 Answers
I think it is not true. because speed of computer depend processer and ram . u can chang high config . ram than using . it can help little make high speed. temp file can make slow so time by time we remove this file. virouse can make slow computer. if bord is short it make hang computer.
Posted on Nov 04, 2009
  • Roshan Rijal
    Roshan Rijal Nov 04, 2009
    change another extra data cable then automatticali detcted . there no need doing another process. some wire problem we see in attaching extra hdd
Machine runs real real slow. Not yet a year old....help
possible problem in foot control or speed control
as it less than a year old it will be under warranty so take it in to a service agent and have it checked under warranty
Feb 24, 2016 | Brother Sewing Machine Project Runway...
Hard to refill gas tank have to pump real slow car runs fine
You've got your gas tank presure release valve.stuck or no good
Jul 15, 2014 | Hyundai Motor 2003 Sonata
91 taurus idles slow and runs rough when cold
spark plugs work better when theyre hot so change spark plugs,
Nov 25, 2013 | 1991 Ford Taurus
Techumseh 195cc lawnboy runs fast then slow then stops
Replace spark plug and air filter.
May 27, 2013 | Garden
Runs real slow and jumpy.slow responce to all commands but downward ok
fuel pressure regulator if it is 4.3 because my truck sits and idles but when u press the gas it die out.
Feb 01, 2010 | 1998 Chevrolet C1500
My son has a 3 year old Craftsman lawnmower with a B&S 6.5HP engine. The engine sounds like it is running slow. It starts real easy and runs smooth but seems to be running slow. Looks like there's no...
There is a governor adjustment on it.Find the governor spring coming from the carburetor the link will lead to a governor spring hooked to a metal tab,by bending the metal tab it will pull the spring tighter making the engine run at a higher rpm
Aug 17, 2009 | Craftsman Garden
Runs real slow
there might be a virus which is causing the problem
Nov 14, 2008 | Toshiba Satellite Pro 6100 Notebook
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
80 people viewed this question
Ekse
Marvin
Marvin
