Acer (4432A-002) CD-RW Burner Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 19 says good soft just bad registry - Acer (4432A-002) CD-RW Burner
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018064
Points
8362
Try this site from Microsoft, it may help with this error code.
http://support.microsoft.com/kb/314060
Usb xHCI compliant host controller registry error
most is the time you have to either change the irq address or try a different pci port for the card. good luck. sometimes another device will cause problems like a mouse or printer cable or something else. also scan for hardware changes sometimes helps. good luck.
tip
How to Fix Registry Errors and Optimize PC?
The Windows registry is a database that stores settings and options for Microsoft Windows operating systems. It contains information and settings for hardware, operating system software, most non-operating system software, and per-user settings. The registry also provides a window into the operation of the kernel, exposing runtime information such as performance counters and currently active hardware. Registry is so important that Microsoft suggest users not to edit it, or it will affect some functions of the system even cause system crash.
The most common registry error is DLL errors. If users frequently install and uninstall software, it can also leave some wrong uninstall entries in the registry. Some anti-virus or anti-spyware will false report and destroy DLL file of some soft ware. Without DLL file, the program will pop up some strange message and can’t run. Also, Control Panel can’t remove DLL files of soft ware. If these DLL files stay in registry, this will cause system errors. Day by day, registry is full of junk files and the computer will run slowly and...
Complete download and guide continues on http://digitalpowering.blogspot.com/2010/04/how-to-fix-registry-errors-and-optimize.html
on Apr 13, 2010 • Computers & Internet
2answers
DVD player not recognized
If your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry.
Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry.
If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option.
Click "Yes" to confirm the deletion.
Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click "Yes" to confirm the deletion.
Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
What is error code 19
A Code 19 error is caused by one or more issues with parts of the Windows Registry that contain driver and other information ..
Follow this blog to solve this error:- http://pcsupport.about.com/od/findbyerrormessage/a/code-19-error.htm
Code 19 Error
How to Fix Windows Error Code 19
f your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry. Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry. If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist.
Instructions
1. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
2 Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
3 Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option. Click "Yes" to confirm the deletion.
4 Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click confirm the deletion.
5 Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
_________________________________________________________________________________________________________________________
How To Fix Registry Code 19 Errors
The Code 19 registry error is caused by a system hardware failure. The failure occurs because the computer is trying to use two drivers for the same device on the computer. When you try to boot your computer, you will get a Code 19 error message that will lock you out of the computer. You can resolve this error by using the Safe Mode option
Instructions
1. Start your computer and then press the "F8" key while it is starting up. This will take you to the "Advanced Boot Options" menu. Scroll down to the "Safe Mode" option with the arrow keys on your keyboard.
2 Press the "Enter" key and wait for the computer to boot into Safe Mode. This should take about 45 seconds to complete. Click the "Start" button when the computer has booted and then click the "Run" box.
3 Type "Regedit" into the run box and press the "Enter" button. This will start your registry checker tool. Wait for the registry checker tool to complete the scan. This should take about one to five minutes to complete. When the scan has completed, you will be prompted to restart your system.
4 Click the "Restart" button when prompted to restart your computer. The computer will restart as normal and the Code 19 error will be fixed.
The Windows registry is a large database that contains the settings and configurations for hardware, programs and applications running on your computer.
GETTING ERROR 19 ON MY HL-DT ST DVDRAM GSA-T40N ATA PLEASE HELP
Windows Error 19 are caused by misconfigured system files.
So, from my experience, If you got Windows Error 19 then there is a 96% chance that your computer has registry problems.
The Windows Error 19 are easy to repair. By downloading and running the registry repair tool WiseFixer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
To Fix the problem you need to follow the 3 steps :
STEP 1: Download & Install WiseFixer for Free using the link below. http://download.wisefixer.com/download/bestlens/WiseFixer.exe
STEP 2: Click "Quick Scan" Button to Scan Your Computer.
STEP 3: Click the "Repair All" Button to Repair Your PC! Then restart and try again
Qsi cdrw/dvd sbw242c in sony vaio computer gives (code 19) it is listed in hardware, but not in my computer and will not recognise any disks.
Error Code 19 Your registry may be bad (Code 19)
I would run a registry cleaner. There are lots to choose from and some of them work like Norton Utilities and PC Tools.
Code 19 error indicating corrupted registry. I've tried uninstalling and reinstalling but nothing works. I have the same problem with my memorex DVD ROM/CD RW drive. I think Norton 360 trashed my registry
yeah, if your registry has been trashed. you should use some registry defrag tools to fix it. I know a <a href="http://www.system-tools-software.com/free-registry-defrag/">free registry defrag</a>, you can look for it and have a try. Good luck!
1helpful
USB trouble with SD1100is
Code 19 Your registry may be bad. (Code 19) To check your registry, click Check Registry. If the registry is bad, Windows will restart your system and go back to a previous registry that is good. Solution button: Check Registry This code means that the registry returned an unknown result. To resolve this issue, follow the recommended solution, which will run Scanreg.exe. If this does not resolve the issue, type "scanreg /restore" (without quotation marks) from a command prompt. Finally, remove the device from Device Manager, and then redetect it using the Add New Hardware tool in Control Panel. Hope this help's ;)
5helpful
UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
