Samsung TXN3071WHF 30" TV Logo
Question about Samsung TXN3071WHF 30" TV
SAMSUNG SLIMFIT HDTV TXTR3093WHX/XAA service menu problem!!!
I'm in desperate need of help! I've got the Samsung Slimfit HDTV model TXT3093WHX/XAA and i went into the service menu, changed the "DEFLECTION" values to correct a problem with my picture but i messed it up worse and forgot to write the original values down. I've got the service manual too but i dont know how use it and set it back to normal the way i had it first... :( Can someone please post me their DEFLECTION values for this set? PLEASE HELP!!!
Posted by o_capellan on
5 Related Answers
Anonymous
SOURCE: it's a Samsung SlimFit HDTV TX-T2782
I was told that it might be a flyback transformer issue. Hope that helps, I'm still looking into getting mine fixed.
Posted on Jan 05, 2008
Anonymous
SOURCE: POOR PICTURE
i have the exact same problem. mine has a yellow tint to it. im
Posted on Aug 11, 2008
Anonymous
  • 98 Answers
SOURCE: samsung slimfit keeps turning off
When the TV is on, how about the back light(you can check that on your TV's back side)
If the back light on -- need to replace Main Board.
no back light -- need to replace Power Board
Posted on Feb 24, 2009
Anonymous
SOURCE: my samsung slim fit tv has a horizontal line which
cordless phone base was too close and was giving interference to the television moved away and solved
Posted on Sep 21, 2009
Anonymous
  • 111 Answers
SOURCE: SlimFit HDTV TX-T2782 TV will not turn on
are you outlets functioning properly? if yes and your sure its the tv, then it sounds like the power supply in the unit has gone bad, or it make be fused, which in that case you would just need to reset it or replace the fuse. I would try trouble shooting on your on first, as a repair can sometimes cost as much as the unit
Posted on May 03, 2010
Samsung 20'' slimfit tube sdtv
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Missing manual
Here is a link to the users manual for your television.
Samsung TXT2793HX XAA Manual
Good luck.
Semper Fi,
Z
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Samsung TX-T2782 Slimfit TV, power turns on, but no video, audio still working.
Resolder the video board that have the long neck CRT(tv tube)have holes connected to the board.
1helpful
Samsung slimfit keeps turning off
Just wanted to know if my TV is HD or not. How can I tell. Model no. is TX-S2789 Samsung Dolby Digital
http://www.hdtv-source.com/reviews/B000F2R5I8_1.html if your tv is similar to this model then yes I assume it is HD.
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
TV takes forever to come on and then very dark
IM Afraid unit required to be serviced , problem at the inverter transformer or faulty capacitors at the POWER SUPPLY unit , hope this helps AJ
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Marvin
Marvin
