Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Eric
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
