Question about Nortel T7316E 2-Line Corded Phone
I am having a problem with the Nortel phone
I'm trying to reset a password on a mailbox, since our system went down a few weeks ago. Most of the mailboxes accepted the default 0000 password and allowed a reset. However, one mailbox will not accept that and says that it's locked, contact admin. Does anyone know the fix on this??
Posted by rsanguinetti on
george peters
    President:
  • Nortel Master
  • 860 Answers
That set may have the general delivery mailbox attached to it. The mail box number for the general delivery mailbox is 100. you might try and resetting that mailbox to see if it gives you access.
Posted on Nov 04, 2009
jithesh keyan
    New Friend:
Hoow can i reset
Posted on Jun 09, 2013
Nortel 7208, locked out of mailbox. Forgot password. tried 120000; says "locked out" can't get in. It is work phone need to get messages. Please help.
To reset the password on the mail box you need to go to a M7310 phone on your system. It has 3 buttons under the display. You need to press the "Feature" button and 983, then enter the password 120000 (this one is used if you have 2 digit extensions 1020000 is used if you have 3 digit extensions) . Next in the display you will see mbox-AA-othr above the soft keys. Press the button below mbox. Next enter your extension number. After that you should see the screen to reset your password. This will reset the password to 0000. When you go back to your own extension and log in to your mailbox it will prompt you to change your password. If you password120000 or 1020000 doesn't work try 121111 or 1021111, the last 4 digits are the password for the admin mailbox.
Mar 02, 2015 | Nortel Norstar M7208 Telephone
Nortel phone - VM box locked contact admin - tried solutions & no luck
Hi Lyndsay,
Have you tried feature 985, and then press 9, and enter the passed resetsmppwd? That should reset the login on feature 983 to 1020000 for three digit extensions, or 102000 for two digit extensions. Once you get into there, you can reset the mailbox password for the general delivery mailbox. Depending on your system, even though the general delivery mailbox might be on extension 363, the mailbox number is likely to be 100.
Jan 04, 2014 | Nortel T7316E 2-Line Corded Phone
I need to change our Auto Attendant message to remove the name of an employee that is no longer with us. I have tried Feature 983 but when I enter the recommended 120000 (we have 2 digit mailboxes) it says...
The best thing to do at this point is to reset the admin. password.
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
To reset your voice mail password, press feature 983 the screen should say log:
enter 120000 (default password)
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Aug 13, 2010 | Nortel T7316E 2-Line Corded Phone
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
Apr 26, 2010 | Nortel Business Series Terminal T7208 -...
I am locked out of my admin mailbox on my nortel nt8b26aabl phone, when i use feature 983 and then password 102000, it says invalid password.???
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Dec 11, 2009 | NorStar T7316E Corded Phone
We have Nortel T7316. I have been locked out of the voicemail admin. I have tried all passwords I can think of but cannot get in. Please help
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
Aug 26, 2009 | NorStar T7316E Corded Phone
My nortel voicemail is locked
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
Jul 07, 2009 | Nortel Business Series Terminal T7208 -...
Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Apr 16, 2009 | NorStar M7324 Telephone
Mailbox problem
The following instructions will only work if your System Administrator password is set to the default. Usually the default is 0000.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Reset a Mailbox Password:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
Oct 21, 2008 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Aug 21, 2007 | NorStar T7316E Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
2,885 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
Adavoid
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
