Question about Hobart Food Mixers
My mother needs a replacement bowl for a Model 4C Hobart mixer . The glass bowl broke last year. My father bought the mixer in the 70's. She has expressed the desire for a dough hook as well. I need to find a catalog or a name and number to call.
Posted by amyedickr on
Ginko
  • Hobart Master
  • 19,396 Answers
Hi.
The Hobart/Kitchenaid model 4C Stand Mixer was produced between 1961 and 1977.
This unit is now a vintage piece chased by collector. Parts dealers do not sell parts anymore for such an old model.
The parts must be purchased on the second hand and vintage market, best source is Ebay. Put 4c mixer or kitchenaid 4c to find parts.
The bowl is easy to find, it is part 4162158, regular retail price for replacement is $44. buy the glass one on Ebay, that will be the original one mounted on first models.
Here Ebay list.
Vintage KitchenAid 4c Glass Mixing Bowl Excel Cond!
VINTAGE KITCHENAID 4C MIXER WIRE WHISK ONLY
KitchenAid Mixer md 4C Complete with Bowl White
KITCHENAID MIXER 4.5QT S.S. BOWL FTIS MODEL 4C 4162158
Here also a forum where you can contact more Kitchenaid vintage appliances owners or collectors.
The dough tool is not even easy to find on Ebay. Try contacting Kitchenaid and see if they can give you a compatible part.
If they have the original one (unlikely) , then do not be surprised if part price is over $30.
If you find a 4c with tools for spares on Ebay , buy it, and resell the parts you do not need. The whole mixer with bowl and one tool is worth over $50.
The original owners manual can also be purchased from Kitchenaid/hobart
Regards.
KitchenAid Customer Service
Posted on Nov 13, 2009
  • 09fastedd Nov 21, 2010
    that model doesn't have a dough hook, it only came with the one whip / paddal, i's only a 200wt mixer.
Ashley Bark
    New Friend:
I realize this post is very old, but for others who may have the same questions, the 4C unfortunately never had a dough hook or paddle made for it as it wasn't strong enough to hold up to thick doughs. I'm sad about that!
Posted on Sep 03, 2016
Kitchenaid mixer glass bowl broke. I need a replacement. I have a 4c mixer. Do you know where I can find one?
The glass bowl for the 4c mixer is much different than the bowls that are currently available. Your best option is going to be to find a used bowl off of eBay.
Your other option would be to replace the bowl lock plate and buy a new bowl for the mixer. I have had a few customers say this works, and I have had a couple say that replacing the bowl lock plate and bowl did not work. So you can give this a try as well.
Mar 28, 2013 | KitchenAid Food Mixers
Mine is a K5-A Hobart Kitchen Aid mixer and the back bowl pin broke off so I can't click the bowl in place any more. Please help!
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
Dec 31, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
Bowl won't stay up
Hi. Goto www.hobartservice.com and register for free.
Search for your mixer model in the Discontinued Products area.
Download file# F6731.pdf On page 4 find the drawing labled PL 2523 If your reassembly geometry doesn't match that of the drawing, you must correct it. If this solution has assisted you please rate it. Good luck!
ricardok45
Mar 22, 2009 | Hobart A200 Stand Mixer
Black & Decker SM100 bowls
My Black and Decker Multi-Mix bowls have both cracked through the base so I had to thorw them out as they are unsafe to use. Where can I purchase replacemetns or what else can I use? I live in hobart, tas.
Dec 08, 2008 | Food Mixers
Hobart V1401 Shaft Broken
I'd advise that you contact your local Hobart Service Branch for guidance on that question. Please visit the service website at www.hobartservice.com and click on 'Locate an Office" - you'll be able to locate the closest Service Branch to you for advice. Hobart does also sell replacement parts to end users direct as well - through the local Service Branch.
thanks
Sherri Wilmoth
Hobart Marketing
Oct 07, 2008 | Hobart Food Mixers
I have a 20 qt Hobart Mixer. The magnet that is needed to allow the unit to run, is missing. We have used a store bought horseshoe style magnet for the last year or so, but does not work now. Do you...
the magnet is in the front gaurd. I suspect you have it taped on the back. looked behind the gaurd and you will see a small nut with a threaded stud looking thing in the neck of the mixer this is a electricl switch the magnet works. maybe your magnet is not ligned up on it or the switch is bad and you need a new one. the head is held on with 4 bolts onder the head is the switch and another switch for the bowl lift. . Best solution is have your front gaurd on and sliding corretly get a new magnet for it and it will lign up. If I cam and fixed it only way I would is with gaurd magnet. Can you tell I am factory trained and been drilled by Hobart lawyers many times. LOL never bypass a Saftey
One thing if mixer does not run at all it could be many things On/oof switch, Timer, bowl lift shwitch. Gaurd switch, realy that runse it in gaurd models. so be to be sure you need me LOL kidding. Good liuck
Sep 11, 2008 | Hobart A200 Stand Mixer
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Oct 27, 2007 | Hobart D300 Stand Mixer
Food Mixers Logo
4,768 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
