Question about Minolta Di251 All-In-One Printer
Misfeed detected but no paper jam
I received a Minolta Di251 copier from a friend. Copier works if I put original on glass. But if I try to use the duplexing document feeder, I get an error saying misfeed detected with a picture showing misfeed at F1. There is never a paper misfeed, in fact the paper never gets started. I have cleaned the rollers at F1.
"Small rollers wheels lower to paper but the small rollers never start turning so paper never gets loaded. There is no misfeed at F1, F2, or along the path.
Also it says replace video imaging unit, but copies do work if I place document on glass.
Where do I buy the imaging unit and about how much?
Is it worth fixing????
Thanks,
Scott
Posted by scottmany101 on
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Nov 21, 2015
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Connecting my Di251 to the finisher
Make sure the actuator pin is still attached to the mid left section of the copier. It's a metal pin about 3 inches long (we call it the "shwartz", ha,ha) that is inserted into the finisher when the finisher is pushed close to the copier.  It is normally mounted with 1 or 2 screws.
Posted on Oct 21, 2007
Anonymous
  • 589 Answers
SOURCE: minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Posted on Feb 10, 2008
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Document feeder
Does the adf show a paper jam? If so remove it or look for some thing blocking the paper path and remove it. Also try to turn off the copier and disreconnect the doc feeder and turn it back on and see what happens.
Posted on Feb 22, 2008
Anonymous
  • 214 Answers
SOURCE: paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
Posted on Jun 19, 2008
Anonymous
  • 29 Answers
SOURCE: Minolta 2350DL laser printer paper jam that will not clear
You have to take off the roller . :)
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
Misfeed detected
have the rollers been replaced, misfeed means the rollers cant grab the paper not a JAM
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Misfeed error but no paper jam in minolta di2510
Where is the miss feed detected 1,2,3,4 draw or bypass tray?
Oct 17, 2012 | Minolta DI2510 Black and White Copier
Misfeed detected. I have opened everything I know how and cannot see a paper jam. The 0 indicator is near the manual 'feed' at the top of the unit.
there is a piece of paper in the area between the tray 1 and the door. sometimes you can use cardstock to push the paper out. try it
Sep 04, 2011 | Konica Minolta Bizhub c203 Copier
Minolta Di251 Paper Feeder doesn't work. Need estimate to repair
Common problem with these models.....most likely if it sounds like it "tries" to feed you original then the feed rollers need to be cleaned. On the front left corner of the document feeder cover there is a single screw. Remove the screw, open the F1 door and the cover will come off. Now right where the originals feed in you will see 4 feed rollers or small "tires" The 2 smaller ones or the usually the main cause. Just take a cloth with some glass cleaner on it and rotate and cleaned both sets of tires. Reinstall the cover and you should be good to go.
Oct 14, 2009 | Konica Minolta DiALTA Di200 Copier
Can't get the copier to scan only 8.5*11 area on glass
Set your original settings to the actual size.
You are using the auto recognition feature which is over-ridden when you specify the size manually.
It will try to match it to the nearest size it "knows". That is why the stamp is detecting so large.
Apr 09, 2009 | Konica Minolta Di1610 Copier
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
Amessage '' misfeed detected'' please remove the .... from 0
before i can help you you need to tell me which brand and model is the machine.
The Message "misfeed detected" means that a paper is bee jammed inside of the copier so you should open some door and remove the paper which has been jammed inside of the copier.
Because of that i need the brand and model of the copier for i to be able to help you and tell you what to do
Jan 29, 2009 | Office Equipment & Supplies
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di251 All-In-One Printer Logo
491 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
