1994 Ford Mustang Logo
Posted on Nov 03, 2009
I need a wireing digram for a 94 mustang for the windows
  • Marvin
    Marvin May 11, 2010
    THERE ARE JUST TWO WIRES.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 03, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
2541
Points
19
Go to your local parts store and get a chiltons repair manual or a haynes repair manual for your particular model, it should cover all your wiring diagrams from motor, to interior. Hope this helps.
O2 sensor wiring digram
The figure shared represents the wiring color code, Number of fuses and Power rating. Along with oxygen sensor wiring, the figure shows entire electrical wiring for 94-95 Buick LeSabre.
Needing wiring digram for a 94 s10 blazer
Go to autozone .com and sign up. they have some diagrahms. Not the best, but may help you.
4helpful
I need timing belt digrams for a 94 ford probe gt has a 6 cylindar engine
moz-screenshot-1.pngAlign the engine timing marks as follows, then install the belt.
Once the belt is routed, as shown below, install the indicated pulley last, then pull the pin out of the hydrualic-tensioner.
Need wireing digram for 94 grand prix se
Try this website for resolving car problems by downloading a FREE service manual for your vehicle. This is not an owners manual but a factory mechcanic's manual.
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
2helpful
Tail lights don t work
Remove the headlamp switch. Check power at the brown wire. If you have power then the problem is after the switch. If you don't have power with the headlamps on then recheck the fuses.
I have a 94 mustang gt. when the car was bought it had been wrecked on the driver side door. the window didn't work, it now has a new door but the window doen't work. I have hook the window motor up to a...
It's quite likely that in the wreck the wires got pinched and are broken inside the insulation. Bend the wire between your fingers and slide your hand along from the switch to the motor and you'll probably feel a spot where it bends easier than the rest of the wire. That would be where it is broken. Cut it and splice it. If you can't feel anything, put a jumper wire on them and that should do the trick. Hope this helps.
1helpful
Need to find the horn relay in a 1993 ford mustang gt I tested the horn and all fuses. I don't have a wiring diagram and chiltons doesn't show the horn circuit
94 was a new model freshening and I have 94. may be similar.
Horn Relay and fuse is in fuse box in engine compartment, driver side in front of strut tower.
Horn System The horn system includes:
  • Dual horns (13832) (one high pitched, one low pitched).
  • Horn blow switch (13A875) which grounds the horn relay, which energizes the horns .
4helpful
Where to find fuse diagram for 95 Ford Mustang?
http://www.allfordmustangs.com/forums/attachments/94-95-tech/608d1036338026-need-fuse-box-diagram-95-gt-esb01113.gif
hope that helps.
1helpful
Need a engine wiring diagram for a 95 Mustang Cobra 302. Alternator is not charging and the wiring harness was hacked in by previous owner.
try these:
www.allfordmustangs.com/forums/attachments/94.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-instrument-cluster.gif
or google: 1995 mustang cobra engine wiring diagram
PLEASE RATE MY ANSWER.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
