Question about TDK DA-3826 2-Disc CD Recorder
Can you hear through the headphone jack when recording and playing
Posted by pianoman77 on
boogiecool
    New Friend:
  • 28 Answers
YOU SHOULD BE ABLE TO HEAR PLAYBACK SIDE NOT RECORD SIDE UNTIL RECORDING IS FINISHED
Posted on Nov 04, 2009
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
IPod Won't Play In Stereo
Dear , your headphone jack needs to be replaced..This is a very common failure in Classic models..However your ipod should work normal Stereo on the dock ..Take care.
Sep 10, 2017 | Apple Audio Players & Recorders
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Headphone jack
when the sound device is installed it should give you sound effect manager or sound device,to access this go to START then CONTROL PANEL then SOUND SPEECH AND AUDIO DEVICE,open Sound Effect Manager,then Sound Effect,select Headphones from the Enviroment Dropdown and click ok.test this output now.
If this doesn't resolve the problem ,
reinstall device again.
Jul 09, 2008 | Acer Aspire 3680 Laptop
Cdr775 New !!!
yes you could record but not with the headphones.
you need to get microphone, it will help you record your cassettes.
Feb 14, 2008 | Audio Players & Recorders
One side mono hearing
You have to sold the jack to the board again, probably one of the conectors lose contact. good luck
Sep 29, 2006 | X-Micro Technology EVA MP3 Player
TDK DA-3826 2-Disc CD Recorder Logo
43 people viewed this question
Top TDK Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Jay Plesset
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
