Question about RCA Televison & Video
NO PICTURE OR SOUND
WHEN YOU TURN ON THE TV YOU HEAR A BUZZ THEN A CLICK NO PICTURE OR SOUND
Posted by esicf on
ABRsvcs
  • 4,234 Answers
The buzz is the power supply attempting to power the set. The click is the unit shutting down. Can you pleae post the make and model as well as whether or not the standby light is blinking? With that info we should be able to give you some options.
Thanks,
Dan
Posted on Nov 03, 2009
Loses picture and shuts off and on
I once had an HDTV with a similar problem. If I turned it back on, it would make a loud BUZZ-BUZZ-Buzz noise for about twenty seconds before coming back on.
I can only guess that the problem is the TV drawing too much power from a circuit that can't support it. Do you have many electronics plugged into the same socket? Is the TV going into a splitter? Try isolating the connection and the TV might have better luck. No guarantees however.
If it's the same problem I had, then it will do this no matter what you hook up to it, as you seem to have at least partially discovered.
Jan 29, 2018 | Sony BRAVIA KDL-46XBR3 46 in. LCD HDTV
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
My tv has no sound
increase the volume to max level .close yourself to TV speaker and listen.if could not hear anything,just turn it off and turn on if you could not hear at least pop sound from the speaker,you will have to replace new speaker.if you are able to hear Buzz noise or very low sound ,sound circuit has to be repaired.
Jun 15, 2011 | JVC Televison & Video
Hi my tv wont turn on. No picture. Just a sound like a buzz. just a black screen.
Model number and brand of tv will help us to understand what kind of tv you have and what could be possible reason of problem for buzz sound when you turn it On.
Without tv model number and brand info, it is not possible to suggest any thing because many kinds of tvs are being used.
Thanks.
Apr 27, 2011 | Televison & Video
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
[email protected]
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Just replaced the lamp inside of a misubishi dlp wd-52525 the tv will turn on then turn off after a couple of minutes. The tv has sound but no picture
1) make sure the lamp door is properly aligned
2) listen to hear the sound of the ballast board trying to ignite the lamp. It will buzz then pause then buzz, etc its a soft noise, so listen closely.
3) watch for the green LED on the TV's front panel. If it blinks continously, there's a major problem with capacitors on several circuit boards requiring an expensive and time consuming repair.
michtech
Feb 19, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
