My heater has the alarm light on and wont heat
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
