Question about Toshiba Satellite LP154W01 Notebook
Toshiba P10 laptop screen no longer works.
My Toshiba P10 laptop screen no longer works. It appears to be slightly backlit but the display is blank. Connecting and switching to the external display works fine. Thought it might have been the inverter so have tried a replacement from ebay but no difference. Guess the replacement inverter could be faulty?
Posted by chris_s644 on
Anonymous
    President:
  • 2,600 Answers
It's not the inverter but the biotin backlight bulb that lights the display from underneath. The screen needs to be replaced unless you want to try and rebuild it and replace the backlight bulb. New screens from EBay should not be more than 70-100 bucks. If you want to try and replace the backlight bulb, the link is below for the procedure.....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Posted on Nov 03, 2009
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
Satellite P10 S429 with black screen after heatsink change
you must have accidentally touched some other parts, just open up the laptop again & look for some unusual things try connecting the wires again. it must be not a big problem. just some loose connections.
Apr 16, 2010 | Toshiba Satellite P10-S429 Notebook
Laptop power is on, but will not load, and screen stays blank
I would take the laptop in to have it fixed. I believe it would be the cord connecting the monitor gone bad.
TRY HITTING "Fn" Button and the F** button that shows multiple displays. Check if the external display works
Apr 10, 2010 | Toshiba Satellite Pro L300 Notebook
CCFL OK but no display
LCD panel. i have several Toshiba laptop with bad LCD.
Nov 04, 2009 | Toshiba Satellite LP154W01 Notebook
Light is on monitor but screen not lit
Dear maynardkb,
Try to right click on desktop, choose properties.
When Display Properties appear, click on the setting tab, you have to choose the related display to make the viewsonic work and allow it to run.
GoodLuck!
Best regards,
bionic23
Oct 28, 2009 | Computers & Internet
My screen to my laptop dose not work what do i do
if its totaly blank , the first thing you should try is connecting it too an external moniter, that will rule out motherboard or graphics card problem if you get a display to an external moniter
Mar 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Monitor is blank!!!!
Firstly, the LCD+external setting will switch one or the other or both on.
Secondly, if you go into your display properties (or even the advanced page where your video card additional features are) you can usually select which monitor is "primary".
I suspect that your external display is primary, and the LCD screen is not "enabled" or used as part of the desktop.
The settings are all there, it's just a matter of finding them (depending on what video card is in whatever laptop you have)
This might have happened in the first place if you accidentally hit "Fn" and one of the "F" keys up the top. Fn + F6 on my laptop will switch LCD/external monitors on and off. (for example) There is usually a little blue picture on one of the "F" keys to denote that function.
Sep 09, 2008 | Toshiba Satellite A105 Notebook
DISPLAY PROBLEM
Check to see if your Video Card is bad by plugging the laptop into an External Monitor... then press the F5 key to toggle it to the external source...If your PC shows up on the second screen, you have video issues...
Jun 04, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite LP154W01 Notebook Logo
286 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
