Pentair Easy Touch Indoor Control Panel for 8 Function Systems Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is the cleaner light blinking? - Pentair Easy Touch Indoor Control Panel for 8 Function Systems
joespools200
Level 2:
Champion:
  • Expert 246 Answers
  • Posted on Dec 07, 2009
joespools200
Expert
Level 2:
Champion:
Answers
246
Questions
0
Helped
125702
Points
332
DELAY IS ON FOR THE SOLAR PANEL OR TH E SPA IS ON
Hoover Smart Wash 52000. The wash and dry light are blinking?
You posted to the category 'Dishwashers', but this looks like it is an Australian Hoover carpet cleaner?
If both lights are on and blinking than they are indicating a jam with the brush roll of your SmartWash.
Hoover SmartWash+ Automatic Carpet Cleaner FH52000
https://www.google.com/search?q=Hoover+Smart+Wash+52000.+wash+and+dry+light+are+blinking
I have a Honeywell HPA050 air purifier. Both filter lights started blinking, so I changed both filters; however, I cannot get the red filter lights to stop blinking. I've held them pushed in, I've...
Ignore the lights. Wash the outer foam filter every two months. As long as air is going through the inner filter does not need to be changed. Blow the inner filter out FROM THE INSIDE with your vacuum cleaner. (blow air the opposite direction of air flow to get the nasty stuff off.)
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
1helpful
Blinking blue light and loud fan
When does the "blinking blue light" appear? As far as the loud fan is concerned, it is possible that your computer has dust built-up inside the case. Open it and try to clean it (GENTLY) with a blower, or a can of compressed air (do NOT use a vacuum cleaner). Specially clean the fan in the middle of the case.
3helpful
2001 chevy blazer 4x4 check engine light flashes on highway no codes?
If it blinks and goes away, it is a "random misfire" that culminates before the light begins blinking. Sustained misfiring will result in a code, and the light staying on. If the light blinks and goes away, the issue is intermittent. Your problem usually occurs under acceleration or heavy load. The issue can often be solved with new spark plugs, though it could also be dirty injectors. The injectors on that vehicle are infamous, however I have been able to fix your problem with repeated use of highly concentrated fuel system cleaner. I use at least 3 times the recommended concentration of whatever cleaner. People rave about Sea Foam. I have used it and it works -- though I can't say whether it worked better than other brands I have used. I have owned 3 Blazers and 2 S-10's, including my current 2001 Blazer LT.
1helpful
Light for airbag is blinking always
try disconnecting the battery and cleaning the connections under both front seats with brake cleaner and then blow them out with an air line and plug back in and reconnect battery
3answers
Dell Dat 72
try a different Cleaner tape, they dont last forever..
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
