Question about Aastra Telecom Aastra 9316 CW Corded Phone
Where is the Call forward button? - Aastra Telecom Aastra 9316 CW Corded Phone
Posted by sandra_horne on
  • sandra_horne Nov 03, 2009
    The link didn't work
william bennett
  • 945 Answers
Http://www.retrevo.com/d/ds/progress?doc=67ab324793d14f7027c630962ba726f8
Ok, this is your manual .I searched for "call forward" and this should help.
Posted on Nov 03, 2009
  • william bennett Nov 03, 2009
    Ok sorry about that if you follow this then input your phone details under manual.Download it its a PDF and search "call forward".
Release forwarding to external number
To program a button to forward on Norstar (if do daily)
Feature * 1
Press spare button
Enter the * code, enter a few pasuses (Feature 78), enter the outside phone number.
i.e *88PPPXXX-XXXX
To program a canel button:
Feature * 1
Press spare button
Enter the * code
Oct 23, 2015 | NorStar M7310 Corded Phone
My machine wouldn't spin nor will it forward through the cycles using the fast forward button
Suspect the control panel unit. Remove the panel and dry if there is moisture, clean the connectors and reset.
Feb 01, 2013 | Washing Machines
How do you program into the dvd that you want it to fast forward quickly? There is a way but am not sure how it is done.
You don't, you just press the FORWARD button on remote during DVD playback to 'fast forward' (pressing this button a second time during playback increases forward scan speed). The forward and reverse buttons have 'SLOW/SEARCH' printed above them on the remote. The other buttons next to them are the PREV/NEXT buttons (SKIP/INDEX).
DVD playback speed/skip/search is mostly a manual user function; it cannot be auto set.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I want the forward slant
The forward slant button is the button to the left of the right shift key. Push that button and it will give you the forward slant.
Jun 02, 2010 | Acer NSK8458AN Keyboard
Using yahoo instead of "outlook express"
Hi..
You can forward using "forward option" button and copies by using "CC" option button apart from main persons in "TO" option button
Apr 16, 2010 | Yahoo Mail
Placing a Forward Button on 1616 IP Phone
What you need to do is, set up a button that will turn forwarding on. then set a number in manager on the forwarding tab, set the number. If the number is going to change a lot, then you should set a second button up as, forward number. One changes or sets the number, and the other toggles forwarding on and off
Sep 04, 2009 | Avaya Computers & Internet
Forward button
Im assuming this is a cheatcode for a specific game, meaning that you move the stick forward as if you were to move your character forward. If this isnt the case please let us know what game you are trying to use this on.
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
My fax is trying to forward to another number. How do I get the forward off of the menu
To use/emable/disable fax forwarding 1. On the all-in-one control panel, press Menu. 2. Use the < or the > button to select Fax setup, and then press . 3. Use the < or the > button to select Fax Recv. setup, and then press . 4. Use the < or the > button to select Forward fax, and then press . 5. Press the > button to select On or Off, and then press . 6. If you turn on the fax-forwarding feature, use the alphanumeric buttons to specify the fax number where the fax is to be sent, and then press to save your selection.
Jun 03, 2009 | HP LaserJet 3050 All-In-One Printer
When we hit *72 the phones automatically go to an answering service (previous employee left and we don't know how it is done) and we no longer have that service so our phones don't forward anywhere. How...
sounds more like an external call forwarding(*72), my guess is that its on a one touch speed dial button. you can either dial the call forwarding manually by pressing the line you wish to forward dialing *72 then the number you wish to transfer to or you can re-program the one touch button by pressing feature 00 pressing the button you want to program and entering the new call forwarding number (i.e. *72 hold 123-4567 *the hold key is a pause).
Mar 14, 2009 | Lucent PARTNER18 Corded Phone
Setting the clock on my baby g shock watch
Press & hold the adjust button until the time starts to flash.
Press mode button to select hours.
Press forward or reverse button to move hour backward or forward.
Press mode button to select minutes.
Press forward or reverse button to move minutes backward or forward.
Repeat the process for the month/dte/dy/yr
Press adjust again when finished
Mar 09, 2008 | Watches
Aastra Telecom Aastra 9316 CW Corded Phone Logo
757 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
