Question about Fuji FinePix 1400 Zoom Digital Camera
Fuji Finepix 1400 Zoom lens cover spring broken
Hi
Is it possible to fix the spring on the lens cover of my Fuji Finepix 1400 Zoom?
It's not a huge problem, but it stay fully open sometimes and I'd like to fix it.
Cheers
Paul
Posted by paul421 on
5 Related Answers
Anonymous
SOURCE: Zoom error
hi i had the same problem with mine,i took the case apart but could see nothing untoward,reassembled it and just out of frustration i turned camera on if you listen carefully you will hear a whirring sound as soon as it starts turn camera off do this repatidly a few times but do not let the motor finish its cycle,hey presto no more fault. i can only assume that the motor sticks and by turning on and off really quickly frees it up...
Posted on Jan 07, 2008
Anonymous
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
david
  • 244 Answers
SOURCE: Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Posted on Apr 08, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: fuji finepix s1000 zoom error lens is stuck out what can I do???
If you recently dropped the camera, you may have damaged the lens housing -- that will require professional repair. Otherwise, your problem may be as simple as low batteries or corrosion on the battery terminals inside the camera. Make sure that the batteries are fresh/fully charged. If the problem persists, remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and replace them in the camera. This cleaning works about 90% of the time, and I hope it clears up your problem.
Posted on Sep 10, 2009
virtualhost
virtualhost
  • 2185 Answers
SOURCE: how do I fix the Zoom Error for Fuji Finepix
Hi Jasmine,
With fresh batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Posted on Dec 13, 2009
Hi does anyone know how to repair or replace a broken zoom on my fuji finefix S1000 camera?
Yes, I do.
You will have to strip the camera down and desolder the main board from the control/flash board just to remove the lens. Once this is done then the lens can be dismantled and the control ribbons desoldered etc, etc....
It's a long job.
And watch out for the springs!
Jan 07, 2010 | Fuji FinePix S1000FD Digital Camera
Fuji finepix a350 zoom error
This problem is quite common with this camera. Try pulling the lens out gently all the way till the lens cover opens. Then you twist it gently till you hear a click and it should be fixed. Let me know how it goes.
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Zoom Error Problem
No, your lens has several very small motors, dust sand or water gets in can cause problems. Fuji has a huge problem with these cameras and bad lens. You will always have this problem and there is no easy fix.
Jul 01, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
ZOOM LENS BROKEN
Most of the digital camera,the zoom lens is the most costly parts,you should consider it to sell it for parts.
Aug 05, 2007 | Fuji FinePix E900 Zoom Digital Camera
Lens cover issue
Check the Fuji Web site - but I fear it will be new camera time when you see the repair price
Aug 03, 2007 | Fuji FinePix F10 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Fuji FinePix 1400 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
