HP Color LaserJet 4600n Printer Logo
Question about HP Color LaserJet 4600n Printer
How do i connect this printer directly to my computer
Posted by carolanalan on
Anonymous
    New Friend:
  • 54 Answers
You Probably should use the printer cable and connect it to your PC
If it asks for the printer drivers, Put the installation CD for the printer
Good luck
Posted on Nov 03, 2009
Anonymous
  • 85 Answers
You will be havin a connecting chord...... connect it to the plug and play port or usb port...........it will ask for installation. install the drivers and use your printer
The printer can not communicate by wireless LAN connection.
Plug it directly into the prayer plug the printer into the computer directly then it hit your Wi-Fi settings and let's connect automatically feel that way then plug the printer from the from the computer and it should be working
2answers
How to I connect my Canon MX310 printer to my laptop?
Hello, you could opt for the USB connection. Plug one end of the cable into the USB port on your computer. After, plug in the power cable and turn on the printer.
2 computers 1 printer
Hi! you must share the printer with that machine witch is directly connected to printer.
Same problem
Is the printer connected directly to the network or to a computer port?
If directly connected to the network, the printer engine is also a print server. It sounds like a DNS issue, not a printer issue.
1. At each computer, in a cmd window, type:
IPCONFIG / ALL
Check the DNS on each one. Change the DNS to the same DNS as the two that are working.
Also, if the computer Operating Systems are different, then they use different drivers. (not likely the problem).
If connected directly to a computer on the network, then the "shares" limit has been reached. (not too likely, either)..
I say it's a DNS issue...
2helpful
Etherner will not connect
The ethernet connection on the printer is for a router.
You don't connect directly to the computer with the ethernet connection.
If you want to connect directly use the usb port on the printer.
2helpful
2answers
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Connecting my computer directly to konica 8020
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Printer Setup & Support Number Call 1-805-225-6690 We are 24 Hour Available Call Now For Help.
I suggest to create a network connection, for the printer.
First, connect the printer directly to one of the computer and then by the network connect the printer to the second computer. The second computer will not be able to scan, but it will be able to print.
Vinaya Kumar...
Vinaya Kumar...
Marvin
Marvin
