Question about Kitchen Appliances - Others
Lights on Rechargable Lantern.. Swissgear SG66301
Please tell me what the three lights, red, green, yellow, mean.. I've been charging the battery for a few hours now, it hasn't been charged in over a year, but only the red light is on..with a hint of the green, but no yellow.. Please explain.
Thanks,
Marilyn
Anonymous
    New Friend:
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Posted on Dec 19, 2009
Testimonial: "Thank you, had to toss the whole thing. This is the worst piece of junk I've ever bought!"
I have been charging my new Brydge for longer than 3 hours and red light has never gone out . I did get the keyboard paired.
13 - To check battery life, press the battery key. The Delete key will flash three times:
Green = 75-100%
Yellow = 25-74%
Red = 10-24%
You need to charge it for about 8 hours on first use and not use it during that time of charging.
Product Instruction Manuals
Oct 05, 2017 | Radio Communications
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
Kitchen Appliances - Others Logo
2,023 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
