Your Back light inverter power board has died. The beeping and blinking are caused by the power board repeatedly trying to start up and failing.
This is a common failure point of LCD monitors after a few years of use. The heat build up in the monitor case causes parts called capacitors to
blow leading to the power supply short. If you can solder you should be
able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm
We have pictures of what to look for. Now take the back off of your
monitor and replace all of the caps that look like the pictures and you
should be back going again. Be sure to use high temp parts, they will
be marked 105c. The values you will need to get will be marked on the
sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert
the new ones be sure to put the polarity stripe going the same
direction as the old one comes out. If you have any questions just let
me know. If you don't want to do the repair yourself we do offer a
repair service for $30 + return .
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
