Question about Acer Aspire™ T180 PC Desktop
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now. and its fine. the problem is, from around 1-5 am, connection on the acer desktop is good. but times like right now, i dont have connection there but i can connect using an older p3 pc..can you help me? thanks
Posted by megace_herna on
Anonymous
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Check your Internet Connection
First thing to start fixing slow Internet is to check whether you are connected to Internet or not. May be you are browsing for those sites which are already stored on your browser cache.
Problem can also be with ISP. You can simply call your support if you are unable to browse websites.
Update Network Driver
Somewhat contribution in slowing down the performance of Internet is an outdated network driver. If your system has outdated version of Network driver, you would face problems similar to Internet super slow to load.
You can upgrade network driver quickly by downloading latest driver for network from your ISP's website.
Configure Internet Connection
Another reason your Internet is super slow to load can be improper configuration of Internet. To properly configure your Internet according to bandwidth, you should download Internet Optimizer.
Internet Optimizer configures your operating system based on the Internet speed. One good internet optimizer is featured in Reginout System Utilities.
Remove Unwanted Toolbars and Extensions
Some toolbars contain malicious code, what happens is that these toolbars are loaded automatically when operating system loads web browser. The toolbars can make your Internet super slow to load.
Check in control panel of Windows, if toolbars are available: uninstall them. If not, check in Tools menu of browser, there would be an option, Manage Add-ons. From here you can disable extensions.
Clean your Browser
Internet super slow to load issue can be due to temporary web content that is stored by browser. To solve this problem, use browser cleaner tool.
Reset Browser Settings
Resting your Internet Explorer can also fix Internet super slow to load issue. To reset IE, perform the steps given below.
  1. Open Internet Explorer.
  2. Click on Tools menu and go to Internet Options.
  3. Advanced tab ' Reset button.
Reduce Size of Web Cache
Web cache can occupy large amount of disk space for storing temporary web content. Internet super slow to load websites can be due to amount of disk space utilized by your browser.
You can easily reduce the amount of disk space utilized by browser for storing web content by performing steps given below.
  2. Click on Tools ' Internet Options ' General Tab
  3. Click on Settings from browsing History frame.
  4. Type 50 value, in the Disk Space to use.
  5. Apply ' OK.
Posted on Jul 04, 2011
Anonymous
    New Friend:
Sun Broadband in the Philippines is very slow, try Smart Bro or Globe Tattoo or better still Dsl line connection.
Posted on Jan 20, 2010
Chris May
    Novelist:
  • 153 Answers
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Posted on Nov 03, 2009
2answers
I have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to...
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
3helpful
How to cofigure my Dlink 502T modem for BSNL connection at chennai
If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . . Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29 Subnet Mask As 255.255.255.0 Default Gateway As 192.168.1.1 Preferred DNS 208.67.222.222 Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem Make sure the Power LED, Link LED and USB/LAN LED are on/blinking Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/ Input as follows USERNAME : admin PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows Name : BSNL
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0 Encapsulation : LLC Select LAN : LAN GROUP 1 PVC : new VPI : 0 VCI : 35 Leave all others at default values Then click apply The go to TOOLS tab Click “system command” (left hand side) Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows Now goto Control Panel->Network Connections Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
Acer Aspire One Netbook wireless internet connectivity problem
Try Resetting Your Wireless Router.. turn it off then back on
then run a repair on your wireless network
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
1helpful
2answers
Can not connect to the internet
In order for you to use your built in wireless card on your Acer, you need to have a way to convert your internet connection in your home to a wireless LAN so your laptop can see it and connect to it. This is done with a wireless router. They are relatively inexpensive and simple to set up.
In order to connect at public wi fi areas such as those that are found at hotels and starbucks, then all you need to do is turn on your computer and make sure your wireless is turned on on your Acer. It should automatically alert you to any wireless signals it finds and you can connect that way.
Thanks for using fixya. Please take a moment to give this solution a rating of fixya since your question has been completely answered. Thanks.
Slow Internet Connect
i have the same router. I recommend that you download a new driver of your lan card for your desktop pc, also if you have P2P and bittorrent applications, try to disable them first and see the difference, those programs slow down the your internet, because they hog your bandwidth and connects to multiple users.
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
3answers
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Acer Aspire™ T180 PC Desktop Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
