Question about Northern Tool HW180DVP Wall Mounted Panel Heater
Thermastic knob does not turn. Brand new out of
Thermastic knob does not turn. Brand new out of box
Posted by leonardcousi on
frankrhoney
  • 89 Answers
Return it to store
Posted on Nov 08, 2009
How much does a 2000 thermastate cost
go to autozone, I bought a brand new thermostate for my 03 for 25$ so yours should be around that price maybe even less
Jan 18, 2014 | 2000 Ford Taurus
I bought this thermastat because it says it also works with millivolt, pellet stoves and "FIREPLACES". I have a Honeywell that operates my furnace and A/C so I know how a programable thermastate...
A thermostat is nothing more than a temperature actuated switch.
A switch breaks a "Hot Wire" going to a load (light,fireplace,fan,etc.)
Dec 26, 2010 | Heating & Cooling
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
Won't go past 60 PSI
Return it as a valve is stuck / not seating.
Mar 05, 2010 | Dewalt D55146 Factory Reconditioned 4.5...
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
How do you utilize the air pressure control knob.
Most air pressure regulator knobs work like a "child-proof" cap on a medicine vial.  It has a spring inside that keeps it dis-engaged from the tooth like gears inside.  To turn the knob you must first pull out or push in the knob.  You should feel some resistance from the spring inside.  As you pull, you will feel the knob seat into the "teeth" inside.  Then you can turn the knob and change the air pressure supplied.   Note:  most air regulator valves work in the opposite manner of regular water valves.  Turning the knob clockwise should increase the air pressure... counter clockwise should decrease the pressure.       I hope this solution will bring you success.   Best Regards,  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Northern Tool HW180DVP Wall Mounted Panel Heater Logo
Top Northern Tool Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Northern Tool Heating and Cooling Expert? Answer questions, earn points and help others
