Question about Spectroniq PLTV-42HW68 42 in. LCD TV
Who sells parts for this tv
The circuit board where the coaxal cables plug into is fried
Posted by arts3rdson on
Bud Martin
  • 11,361 Answers
I Have a COBY 50i inch, We had a thunder storm wiped out my cable boxes & I think it wipe out my TV. It wont even turn on. Do you think its fried
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 11, 2016 | Coby Televison & Video
I have sound, blue and green color, but no red. model R57W46
Change tv to another incomming broadcasting signal coaxal cable wire plug into it,might be lucky,the incomming signal wire is the problems.If it is not the incommming signal coaxal wire plug in.Than the tv RED color gun is dead,might have a dead CRT tube RED color gun.This problems is not easy to be fixed or determine.Should hire a tv tech to troubleshoot and rerpair.
Mar 16, 2011 | Zenith R57W46 57" Rear Projection...
We just recently had a power outage and I think it may have fried my television but I'm not sure what is actually fried. I can plug it in and hit the power button and the green light on the front blinks...
I have the exact TV. Mine works just fine but the screen is cracked. I can't find a replacement screen anywhere. I would be glad to either buy your screen to replace my broken one or I could sell you the circuit boards from inside mine for $50.00. And you can just replace your boards with some that work. You can reach me at [email protected] I live in the Houston Area. Email me with your number and I'll call you.
Dec 28, 2010 | Sanyo DP32648 32 in. LCD TV
The coaxal cable input got ripped off the tv...how can I fix this?
The only best and fastest way with no coplication to the tv,just replaced the whole tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Dec 20, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Motherboard is fried, what can i do?
Try website like Tvrepairworld.com,Ebay.com to buy a refurbish mother board,they might have it.Don't it time to buy and replaced for a LCD tv better tv over all as a tv and for buying for replacement parts later for replacement for tv needed parts later on as LCD tv needed circuit board for parts.
Dec 13, 2010 | JVC AV-56P575 56" Rear Projection...
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
RCA REAR PROJECTION 52inch 1999 model
get a new cable. the connector on the cable is bad.
the center pin of the cable connector is the signal carrier, and the outer jacket is the ground. so if wiggle the cable and the cable and the pic become clear, then it is definitely is the cable.
Oct 19, 2008 | RCA HD52W56 52" Rear Projection HDTV
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
Spectroniq PLTV-42HW68 42 in. LCD TV Logo
103 people viewed this question
Top Spectroniq Televison & Video Experts
ray gallant
Stan Ford
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
