Question about Adaptec Computers & Internet
Huge problem with an old Garage door opener. And no, I can't just ''go buy a new one''. So, here's the deal. The light quit coming on when the door was opened, so I took most of the circuitry apart. The huge mistake I made was I made great diagrams of everything but where the 3 wires that control the thing hook up to the receiving unit and to the push button in the garage. I have a really good diagram made of it if that would help, and it's an old Genie model 209. Where the receiving unit hooks up, which has 3 wires, white, black, and red, there are 3 wires from the inside of the unit, grey, pink, and purple, plus, on 2 of these connections, the push button switch connects. In other words, there is a connection block with 3 connectors: the 3 wires from inside the unit itself connect [grey, pink, purple], and also, the receiving unit connects to all 3 terminals, plus the push button connects to 2 of them. How I forgot to write this down I'll never know ! But surely, surely, someone out there has an old Genie, or knows enough about them to help me figure this out.
Posted by Billy Dunshie on
5 Related Answers
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
Posted on May 21, 2008
Anonymous
  • 94 Answers
SOURCE: On/off switch on zd7000 laptop
Verify that the case is firmly seated. If the plastic top is not seat correctly to the board, the mobo power button is not close enough to make contact with the button on the snap off panel, where the external plastic power button is.
Posted on Sep 12, 2008
Anonymous
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
Fabio
  • 400 Answers
SOURCE: I need the wiring diagram
Could you tell us what the model and make of the sewing machine is please.
Posted on Nov 03, 2009
Anonymous
  • 143 Answers
SOURCE: Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
Posted on Jun 06, 2010
My garage door transmitter is mot working, if I buy a new one, how to set the code?
Wow, Ken. Tons more information is needed to fully answer your question. The make, AGE, model information, for instance.
However, you will be one of a couple of methods.
When you buy the replacement remote, consider buying it from a garage door place, they often can take the old remote and make the new one work.
Way older openers use a bank of switches.
Newer units use electronic handshaking. This is where you push an "invite" button on the unit and then press buttons on the remoteS, to get them to handshake. Directions can sometimes be found on the opener unit.
While you are up there, get the make, model and serial # so that you can get the right remote the first time.
The nice thing about the electronic units is they are SAFER and tons more secure. After the handshake, each time the remote is used, the access code is "rolled" automatically. Digital access prevention is a huge step forward.
Jan 26, 2015 | Building Materials
Lincoln Navigator key fob and garage door opener quit working
I'm not sure, but I would assume there is a module involved
Mar 06, 2014 | 1998 Lincoln Navigator
Nnew Sears garage door opener - old keypad
Yes,buy the new keypad in the safe side.Probally have new Inferred signal codes by the new remote might work with the old keypad.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftman Garage Door Opener is approx. 7 yrs old. Remotes work fine. Keypad acknowledges receiving code, but then will not open door. Installed new bsttery.
If your keypad is the same age as your door and worked before it has probably just quit. If it is new and you have programmed it and it still doesn't work it may be the wrong one for your model opener.
Oct 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Blowing out light bulbs
There are rough service bulbs you can buy at hardware stores. You can also try unplugging the unit and using a small screwdriver pull out on the center contact in the light bulb socket.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
New eye sensor not lighting up when installed
Make sure the sensors are pointed at one another. Also one of them should say "sending unit" and the other is the "receiving unit". Did you buy them new and from a dealer?
Jun 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1\2 hp clicks, motor wurrs for 1 sec', but doesn't open
You have a stripped gear on the opener. Take off the cover on the motor. The bottom of the cover will be filled with white shavings. You can repair this with a "liftmaster gear and sprocket assembly".
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Do I need to replace everything, if I buy a new garage door open.
My 15 year old system broke down due to a worn screw drive. While parts like this can be replaced, it takes a bit of guts to work inside the motor, and the circuit board. I chose to buy a new unit. New units come with all the parts ... so you don't really save much, Depending on how old the system is, the old accessories may or may not work. Even though my old 1/2 H.P. motor was a chain drive, when I bought a new screw drive the mounting parts on the ceiling and on the wall above the door were compatable. So while you get the new parts in the box, you can use the old parts if it saves you time. I was not able to save the electic eye components as the number of wire leads was slightly different in the new model. It took me and my son about 2 hours to get the old one down and the new on up. Hope that helps. (by the way, the new chain drive is quicker and quieter)
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Computers & Internet Logo
204 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
