Had working sky remote in bedroom, now no remote sky operation from upstairs, is there a secret installer code to switch this function on?
Posted by m_e_autoelec on
Jamie Andrew Knights
  • 244 Answers
Have you got a magic eye in the bedroom,if so the little red light should be on,if it is not then you are not getting a signal from the main box.You need to check the 2nd rf output is switched on in the main box.
Posted on Nov 04, 2009
I have just got a sky+hd 2tb box installed, i have a wireless transmitter and sender that i use to watch sky upstairs in my bedroom, i can get sky upstairs through the wireless scart connector/video sender...
You need to find out if you remote is infrared or radio frequency. If infrared then there are remote extender devices that you can purchase to use your remote. If it is RF, then your search would be the RF remote extender box.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Jul 02, 2014 | Computers & Internet
Code for Sky remote for AlbaALCD15DVD2 tv Thanks TH
Hello
Sky remote codes to check with Alba TV are:
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 20, 2011 | Televison & Video
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
OK.
Aug 30, 2011 | Samsung Televison & Video
I have a Humax LU23 TD2 television and have now got Sky tv. I would like to know how to use the Sky remote to control all the functions such as power on, volume etc. for the tv. Can you help...
Hello
These are the setup processes for Sky TV.
OK.
Aug 28, 2011 | Televison & Video
Hi need code for sky remote for sony kdl402530
Hello
Sky remote codes to check with Sony are:
533 038 039 064 102 130 505
679
505
5* Point the Sky+ remote control at the TV and try the volume button.
OK.
Aug 25, 2011 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Aug 20, 2011 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Televison & Video Logo
271 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
