Question about Nortel T7316E 2-Line Corded Phone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
Posted by teresaf810 on
george peters
    President:
  • Nortel Master
  • 860 Answers
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Posted on Nov 02, 2009
Hello, i have a nortel 7316e and trying to reset to factory default. i am entering **7827887 and error message "startup denied" appears. Thanks Nikko
Remember to hit "Feature" first. Dialing **7827887 by itself does nothing.
EG;
1 - Feature **7827887 (STARTUP)
2 - Enter installer password 266344 (CONFIG)
3 - Change to template desired (square, hybrid, or PBX)
4 - Press NEXT to apply the template
Edit: Make sure you have access to the phone pool as admin and that there are no restrictions set on the phone itself. The same thing was happening to others and was detailed here
http://www.tek-tips.com/viewthread.cfm?qid=983869
Feb 23, 2017 | Nortel Computers & Internet
How to disable the speaker on the phone
On most older nortel systems you can use the feature,*,6 buttons to adjust the ringer type, along with type you can set the volume by using the up/down volume buttons.
Jun 21, 2013 | Nortel refurbished 7316e phone
How to find my mac address for nortel t7316e
A T-7316e not having an internet CAT5 connection does not have a MAC address.
Mar 31, 2013 | Nortel Networks Business Series Terminal...
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
Jul 09, 2010 | NorStar M7208 Corded Phone
Our Nortel 7316E office system appears to be locked on intercom. We cannot complete an outgoing call. Please HELP!
moz-screenshot.pngHave you tried the hang-up button? It has the phone with the arrow down? Some phones have a Rls button instead.
What you need to do is hit the weird circle like key and the #802 to cancel intercom
Mar 10, 2010 | Lands Phones
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
Need to listen to office voicemail from home
Dial ** when your voicemail answers. Follow prompts.
Dec 19, 2008 | Nortel T7316E 2-Line Corded Phone
Norstar Mailbox Problem
The mailboxes don't need to have saved messages, to be full. More then likely what is happening is that when people call in, they are getting a generic/Auto Attendant vm box, and that one is full. Try checking vm box #100, or #10. That is the Nortel standard general delivery vm box. Please let me know is this helps, or if you more help.
May 25, 2007 | NorStar M7310 Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
616 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Rich Barnett
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
