SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
Best first step = change lamp
SOURCE: Won't turn on. Green power light blinks for 30 seconds and then red lamp light blinks constantly
If the lamp light is lit, it is likely a bad lamp. If you remove the lamp from the set, you will either see shards of glass in the housing and/or a very cloudy reflector (it should look like a mirror). Be sure to use an original Sony lamp as the replacements are trouble makers. Please be sure to rate this solution. Thanks!
SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
SOURCE: my red light is blinking 3 times, the picture
Hi,It sounds like an issue with the board that powers the lamp it's called the ballast.The ballast has a sensor that it detects when lamp is not responding or if ballast is not able to provide enough power to light it up,that's when you get the lamp indicator.This is the most common failure .When you put a new bulb in sometimes the ballast is not able to power it since it uses more voltage that what it was providing to the old lamp.The ballast is something easy to replace and it's cheaper than the lamp.Have a bless one!
Testimonial: "Thank you so much, and God Bless you. Also how can I replace tha Ballast and where is it located. Thx."
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
