My camera is showing Internal Memory full, and I have a memory card inside of 2GB it doesn't recognise it, and it is empty. I've also tried the old memory card which came with the camera and it doesn't that either. Whats happened? Has the card reader broke?
Yea pls do check with the card reader.....as u tell above criteria the problem will surely be with the card reader....
but in the mean time pls use some other memory card to check whthr its working or not....before using it format n try,.....gud luck
thnx fa usin fixya!!!!!
Check the manual for any such thing like "memory card problem" or open the page that talks about it, it may contain useful info
usually there is a preferred type recommended to use
using a memory card that was installed in other cameras may change its format or file structure, this may cause your camera not to recognize it, try formatting the card and then install it again, most cameras have a "format" option in the menu, try it out
there might be a "reset to factory defaults" option, this may reset your camera to the way it was originally it was in, could solve it
Question edited for FULL 'make model (what it is).
Question moved to 'make model' category.
Duplicate post deleted, two posts made into one. Refresh page to see your question published.
Usually, cameras come with a certain amount of internal memory before it fills up.In this case, your camera has about 10 pictures worth of memory before it is full (see picture).
You can get more space by purchasing an SD memory card from any office supply or electronics store.
You can also upload your pictures to your computer with your USB cable,then deleting the photos one the camera. The instructions on how to do this are in your manual.(If you don't have the manual at hand, there is a link here, see page 18)
How many pictures one SD card will show is shown in this chart:
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it. After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card. 1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards. Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmware
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
