Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Not heating up
The dryer is spinning and blowing out cold air, so the dryer is spinning and blowing out cold air, so nothing is drying as it is not getting warm
Posted by kate_comer on
Anonymous
    New Friend:
  • 37 Answers
Some times the heating coil breaks or the thermal resistor goes bad
Posted on Nov 02, 2009
I have a bosch wtm3300 dryer and it was in a flood, I let it dry our for a week or so, then turned it on, it spins and blows cold air.
Check the circuit breaker for the dryer. It most likely has one leg tripped internally. This will allow only 120 to operate the motor and controls, but not the heating element.
Jan 15, 2017 | Bosch Dryers
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
The dryer will not heat up to dry clothes
youve probably got a bad heating element, also make sure air is blowing out back of dryer to the outside of house if its plugged it will cause element to break good luck
Mar 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Won't Dry
Try taking off the duct from the dryer, it has to be something blocking the air flow, check if the end of the dryer is trowing out air, if it is not, then you have to take it apart to see if there is an obstruction inside of it
Dec 17, 2007 | Kenmore 62872 Electric Dryer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
