Question about Sunpak Cameras
I have a Sunpak PZ42X for Canon and a Canon T1i. The camera does not recognize the flash when it is in the ttl mode, but the flash will fire when attached to the camera in the M mode. Sunpak indicates it is compatible...any suggestions?
Posted by lmcdaniel516 on
  • Anonymous Mar 28, 2014
    My sunpak flashgun only work on TTL not in manual settings. What to do?
Anonymous
    New Friend:
I have the same problem and i dont have a idea to solve it. Did you do something?
Posted on Feb 26, 2010
Using a Sunpak 555 with Cybersync transmitters with a canon 40D off camera and getting inconsistent firing
did you find a solution? ive experienced a similiar problem. i think i might need to buy new flashes.
Aug 13, 2012 | Sunpak Auto 555 TTL Flash
Flash zoom head does not properly track zoom lens position
That's the sort of problem which will occur with third-party supplier products.
You don't give any useful details regarding how inaccurate the tracking is, but accurate tracking is not usually critical. Check your flash photo results. Are they fine? If so, no problem.
In any case, if the error is affecting your images then there is absolutely nothing you can do yourself to fix this. Your only choices are to either return the flash for a refund or exchange (other units will likely be the same) or to contact SunPak for advice, but they'll likely try to blame your camera, and Canon will clearly say that they cannot be responsible for equipment they didn't design.
The only sure way to get a fully compatible and accurately tracking flash is to buy the expensive Canon model. You pays your money and you takes your choice.
Jun 17, 2011 | Sunpak PZ42X TTL Flash for Canon
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Can i use my sunpak 4000af with my canon rebel t1i?
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Sep 30, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
Sunpak pz 4000af for minolta
The Alpha 100 only supports pre-flash TTL and ADI flash control which are not supported by the Sunpak. The flash should ignite, but automatic controlling of its brightness is not possible.
For more Information about the different Minolta/Sony Flash Metering modes cf. http://www.mhohner.de/sony-minolta/flashcomp_mm.php
Jan 20, 2008 | Sunpak PZ 4000AF for Canon TTL Flash
Cameras Logo
Top Sunpak Cameras Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
