My Lg 42pg20 Plasma will not turn on.. Theres nothing.. no light, sound or anything. its dead. anyone have any idea whats wrong.
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
If you have a bad power supply board on an LG or Vizo plasma TV (they're the same basic model) then instead of trying to repair the existing power supply I would recommend replacing the entire board with a new one or a known good used one. I have a 42" LG plasma TV (model #42PC3d) and was able to get a replacement power supply from Ebay.com for $30 - shipping included. Replacing the board is pretty simple just follow these steps:
1. Take off the sheet metal back plate off the TV (there are a LOT of fasteners)
2. Disconnect all of the wiring harness plugs from the board and hold the wire harnesses out of the way.
3. Remove the four screws holding the power supply board to the back of the TV and remove the board.
4. Install the new board, connect the wire harnesses and install the back on the TV.
BTW - The power supply board is in the middle of the back of the TV towards the top and has several transformers on it with yellow plastic coverings on them. The boards at each end of the TV on the back are the Y and Z Sustain boards.
42pg20 has no power. The set turned on with no picture or sound. Then the power was gone.
