Question about Toshiba Equium 100 PC Desktop
My toshiba equium L100 186 " laptop" willnot power up.
My toshiba equium L100 186 has shutdown on overheat which it has done before but this time it will not start at all. Green power light comes on and stays on - hard disc light blinks once and goes out - green battery light stays on. Optical drive opens and closes, recovery disc has no effect. Screen does not illuminate.
Regards,
David M.
Anonymous
    New Friend:
Panic over.
Tried the computer after about three hours and it worked. Something somewhere must have reset itself.
Thanks to all who had considered this problem.
Regards,
David M
Posted on Nov 03, 2009
Anonymous
  • 52 Answers
Replace motherboard
Anonymous
    New Friend:
DAVID M...WANT TO SELL THAT LAPTOP TO ME? ILL BUY IT...SOUNDS LIKE IT NEEDS A MOTHERBOARD. I NEED THE LCD OFF IT. [email protected] email me
Posted on Dec 08, 2009
Why won't my Toshiba Equium P200D-139 laptop stay on
It sounds like either the battery needs replacing or you need a new power supply.
If it works while plugged into the power and only shuts off when unplugged then it's the battery otherwise it's the power supply.
Thread Equium P200D 139 battery seems to be dead
Jul 28, 2015 | Toshiba Computers & Internet
I have a toshiba laptop equium a100 laptop want to restore back to factory settings how do i do this
The best option is get a restore disc from Toshiba, I've done this a few times and it is a very easy process. Once you have the disc just boot the laptop with disc inserted and away you go!!.
Look here :-
https://backupmedia.toshiba.eu/
Jun 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
My Toshiba Equium starts up ok but when I start using it it shuts down (as if power has been removed) any thoughts
If the Toshiba shuts down and then cannot boot up straight away until it has cooled down, then you could have an overheating problem.
This is caused by a faulty fan and/or dust blocking the heatsink/fan assembly.
When the CPU overheats it goes into a thermal shutdown, and if you continue to ignore this problem, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the fan, if the fan and heatsink/vents are clogged with dust then loosen and remove/vacuum the dust.
Dec 14, 2009 | Toshiba Computers & Internet
Laptop equium l10
Hi, My Name is Henry. I am one of the technicians here.
You need to upgrade your bios. Go to the http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click download and follow the instructions.
NOTE THAT YOU HAVE TO BE VERY CAREFUL WHEN UPDATING THE BIOS BECAUSE YOU COMPUTER MAY DEVELOP MORE PROBLEMS IF YOU DO IT WRONGLY.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 17, 2009 | Toshiba Equium 7100S PC Desktop
Restoring factory settings
You can restore your laptop using a regular windows cd, formatting the disk and reinstalling the OS again. After that all the devices which the drivers are not included on the windows CD like for example; network, sound, video, you can download them from the manufacturer website and complete in this way the process to restore your laptop to zero.
Nov 15, 2008 | Toshiba Equium 3150M PC Desktop
Upgrade the processor on a Toshiba equium l40 series from a celron M
The core2 duo chips will be a different socket to your celeron cpu so can do that unfortunately. You may be able to upgrade to a faster cpu of the same socket type but will probably need a bios update for it to run at proper speed.
Unfortunately laptops arent really designed to be upgraded at all bar extra ram/hd/dvdrw.
Hope that helps?
Dec 26, 2007 | Toshiba Celeron, 2.50 GHz (P000396980)...
Toshiba Equium 100 PC Desktop Logo
423 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
