If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Hi friend, thank you for your post!
I understand that the oven will not hold temperature properly inside your Frigidaire range. I would perform a reset which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
