Question about Food Mixers
I have a 6qt professional kitchenaid mixer and that I bought last year and have just recently started to use it but it make a high pitched squeal that makes it almost unbearable for me to use. If anyone can help please let me know. Thanks, Diane
Howard Lincoln
  • 235 Answers
Diane,
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... but alas they do not. So much for quality in America today!
Posted on Nov 02, 2009
Testimonial: "Thank you I will check it out! It just bums me out that it has a problem already. Diane"
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
One speed on slide switch will not go high or low
It's most likely a bad sensor. If a new sensor doesn't fix the problem, then the circuit board would have to be replaced as well.
Nov 12, 2014 | KitchenAid KP26M1XPM Professional 600...
How to remove stuck bevel gear off planetary shaft in KitchenAid 6qt professional mixer
That should just lift off, I'm not familiar with your particular model but all the bevel gears I have seen just drop onto a pin that is just a push fit through a hole in the shaft.
Oct 26, 2013 | KitchenAid KP26M1X Stand Mixer
I have the professional 600 - 6QT - 575W mixer.
It appears that retaining ring (7) has snapped. It is the retaining ring which attaches to the drive shaft. Here is the parts diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208211764.pdf
From it you can see how to remove the case cover and access the gear train. You may have to replace the shaft if its groove is worn allowing the retaining ring to slip off.
Apr 18, 2010 | KitchenAid KP26M1X Stand Mixer
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
Motor is running but the paddle won't move.
If you bought this mixer less then 1 year ago, call KitchenAid at 800-541-6390. They have a "hassle-free replacement" warranty. They should ship you another mixer. I bought one recently and it died after 3 days of use. I called and they are sending me a new one. However, it is not comforting that these mixers fail so quickly. KithenAid use to be made a product to last many years. I assume the quality has declined. Good luck!
Dec 22, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
282 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
