I have hundreds of customers using nothing but non-original toners with no problems. Just stay away from anything that seems way to cheap and you will be fine. Here is a link to a source I use. If you are creative and can set up an account as a service person you can get discounts as well.
http://www.precisionroller.com/search.php?q=km1820+toner
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
