Canon PIXMA iP3000 InkJet Photo Printer Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an IP3000 printer and each time it is turned on it goes into error mode (the on light blinks amber 5 times then turns green for about 1 second then it flashes amber again
Graciano Leitao
Level 2:
  • Expert 51 Answers
  • Posted on Nov 02, 2009
Graciano Leitao
Expert
Level 2:
Answers
51
Questions
Helped
46532
Points
166
I. Make sure the printer is off but is plugged in
II. Hold down [RESUME] (Triangle pointed down) and hold down [POWER]
and wait 5 seconds or so.
Release [RESUME] but Continue to hold [POWER]. Double click [RESUME].
then Release [POWER].
Press [RESUME], than [POWER]. This should cause the printer to print a
simple diagnostic that'll list it's ROM number and list CDR SENSOR=OK
in red for the last line.
Press [RESUME] twice then [POWER]] to print off the second diagnostic.
Press [POWER] by it self to exit service mode and return to being a
printer.
Service error 6B00.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
2answers
Printhead is not recognizing the ink cartridges
Canon IP3000 INK counter reset
1. Turn off printer
8. Your printer should respond as normal..
All The Best Pineworks
4helpful
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
PIXMA Ip3000 with one orange and one green flash error
Hi may work
1. Turn off printer
2helpful
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
1helpful
2answers
Canon IP3000 error code
read entire solution first, see the 6 modes section.
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
PIXMA IP 3000 service error 5100
to fix it
1. Turn off printer
or: and Also;
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
1. Turn off printer
old marine
old marine
ZJ Limited
ZJ Limited
