Question about JVC AV-32120 32" TV
While watching the TV, it just get shut off by itself.
Posted by suuma on
AMJAD HUSSAIN
  • JVC Master
  • 586 Answers
The problem is in power supply, If you want to repair it by your self then please let me know that do you have proper tools for it to repair,if yes then please re post the thread again. And if you are not familiar to this job then please call any expert nearby, because its a bit technical procedure to find the part of problem.
Thanks for using fixya.
Posted on Nov 02, 2009
Tv Shuts off By Itself
When something like that happens the problem is probably in the power supply section of the receiver.
Jun 20, 2016 | Mitsubishi Televison & Video
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Tv shut off by itself
its a power supply problem
Mar 03, 2014 | Sharp LC37D64U 37 in. LCD HDTV
My apex tv shut itself off and it will not turn back on. I watching tv and it shut itself off and will not come back on. I do not have an remote for it.
i believe your sleep timer is still set.. go to the menu and find your sleep timer options turn on or off with volume buttons..that should help
Apr 26, 2012 | Apex Digital AT2708 27" TV
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony wega engine 3lcd. turns itself off
It must be dlp tv that use lamp, is it?
If its true then replace lamp in tv that reached to end of its working life span and causing problem.
Your question shows it is CRT tv but symptom says it would be dlp tv.
Let me know if you have additional question about tv.
Jul 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Olevia TV shut off by itself.
You probably have either loose solder joints or components that failed after heats up. You need to look inside to see. Learn more about failed TV and monitors, caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Televison & Video
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
