The 2 back tires on my brand new quinny buzz are flat. Is there a special pump needed for these tires? We have tried 3 different pumps and they don't fit the tires.
hi you can get a new wheel unit from quinny direct or eBay the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40 if that doesn't work it may need a re gas which can done by quinny
Yes there is an inner tube which sounds as if it has a puncture. I bought replacement inner tubes off e bay for mine when the same happened to mine. You can then either take the tyre off yourself and replace the tube (bit fiddly unless you have a suitable tool like a strong screwdriver for releasing the tyre) or try taking it to your local bicycle shop who could no doubt remove and refit the tyre for you for a small fee.
Hi you can purchase the correct pump on ebay, if they are punctured they also sell new inner tubes very cheap they also have a bent valve which makes them easier to pump up.
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
this will not effect the safety of this item x you might be able to get this back to its original postion if you clase and fasten the pram and then try and fix this issue hope this helps x you can contct dorel.co.uk by phone who are the only impoters and spares stockists fro quinnys in the uk and do fix faulty or broken quinnys there is a charge but would be alot cheaper than buying a new pram x
