Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Yamaha EF1000is, Will no run without choke on
I have a Yamaha EF1000is, that will not stay running unless the choke is pulled out. If I push the choke in, it revs up, then nearly dies, then revs up etc, until it does finally die. Any ideas on what the problem may be?
Fred Yearian
  • Yamaha Master
  • 5,603 Answers
It is starved for fuel. PROBABLY needs to have carbureator cleaned and adjusted OR the fuel filter may be clogged.
Posted on Nov 02, 2009
Testimonial: "Thanks for the help, it turned out that the intake jet was totally plugged. Cleaned it out and it runs great."
Anonymous
    New Friend:
  • 4 Answers
I have the same thing. picked it up used. I did clean the carb, BUT I think that one needs to do more then just gently **** out the jets with a fine piece of COPPER wire. Try soaking all the carb parts on a carb cleaner for a few hours and blow everything put with compressed air.
Posted on Dec 06, 2009
  • Anonymous Feb 12, 2011
    I have the same problem, after carb cleaner and fuel filter .do you have another solution ?
  • Ed Greene
    Ed Greene Dec 06, 2016
    your idle jet is clogged. get seafoam or carb cleaner spray and spray into tiny hole near choke flutter behind the air filter. start the engine cold and spray it in the tiny hole with he straw provided on can. if this does not work repeat but only spray small amounts so the engine dont stall. also remove end cap on exaust and clean out spark arrester and keep out while spraying into carb. works wonders
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
Why motorcycle starts but only stays running when I open throttle?
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
http://www.motorcycleforum.com/59-motorcycle-repair/109746-only-runs-when-choke.html
Bike starts up idles on choke dies with choke off our when warm
Yamaha XVS13AWC Service Manual
OEM parts for Yamaha
Yamaha XVS13AW Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 06, 2014 | 2008 Yamaha V Star 1300 Tourer
2003 Yamaha TT-R 225 will not run without the choke being on
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Will not run without choke and runs badly 2003 TTR225
wont idle without some choke
http://tjsconcepts.com/ttr225/TTR225_Service_Manual.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
http://tjsconcepts.com/ttr225/TTR225_Owner_Manual.pdf
Jan 08, 2018 | 2003 Yamaha TT-R 225
I have a 1984 Maxim XS 400 L that won't stay running unless choke is on
Hi, Dmg24jeff and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Only runs when choked
Bike won Run without Choke
Yamaha XS400 1977 1982 Factory Service Repair Manual PDF Download Manuals... $10
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
May 23, 2012 | 1984 Yamaha XS 400 L Maxim
93 yamaha 40 hp runs only when choke is pulled out push it in it dies
clean the carb/s as the jets etc sound like they are blocked !
Apr 23, 2012 | Yamaha Boating
Hi there i have a 2004 Yamaha YZF 250 that will run on choke then push the choke in as soon as u give it throttle its bogs an back fires then dies or u can build the revs it runs jst bout thanks
Would almost certainly be blocked pilot jet and pilot circuit a classic symptom of this is running only with choke on
buy new pilot jet an compress air clean the hole the pilot jet screws into
regards Jamie
Aug 28, 2011 | 2004 Yamaha YZ 250 F
My cbr 600 f2 1993 had been sitting for a long time
Sounds like the carbs were not properly cleaned or set up. Choke should cause the cold start rpms to be higher than what you are experiencing. Application of choke to a warmed up engine will usually cause the engine to stall.
Jun 28, 2010 | 1994 Honda CBR 600 F(2)R
Yamaha ttr125l will not stay running. will start
The idle circuit of the carburetor is likely clogged.
Jun 24, 2010 | 2004 Yamaha TT-R 125 L
1993 blaster wont stay running
try cleaning carb and see if the choke is hung up also make sure it has the right plug ngk b8es
Feb 22, 2009 | 2003 Yamaha YZ 250
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
1,760 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
