Question about Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
I noticed that my monitor has an additional port to connect another monitor to but for some reason its not recognizing the monitor
  • 909 Answers
Well, likely that the 2nd port is another way to connect the monitor to the computer. Or, connect the monitor to a second computer and flip between the inputs. highly unusual to feed 1 monitor off of another.
Posted on Nov 02, 2009
  • 488 Answers
Is that a port for an additional monitor or is it simply an alternative method of connecting the monitor to the PC. My monitor has a vga input along with a dvi input and a hdmi input. These are all inputs not outputs.. Unless the port is specifically labeled as an additional monitor output, the chances are its an input.. You may have to use proprietry software to make any additional outputs available.. if the monitor is a Samsung, go to the samsung website and search for the monitor model. or read the manual..
I have a notebook of LENOVO Y580.I found problem that the notebook cannot connect two additional monitors at same time. the one connection to ASUS PA248Q with HDMI port, the second connection to PRINCETON...
The graphics card can only support two monitors at a time. One being the notebooks built-in display and the other being either the HDMI or VGA ports. You will have to attempt to disable the notebooks built-in display. Good luck.
Dec 22, 2017 | Lenovo IdeaPad Y580 2099 laptop
HOW DO I KNOW IF MY VGA PORT IS ENABLED?
Press, and hold down on the Fn key, and AT THE SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
There are at least 3 display options;
1) Internal monitor of laptop ONLY.
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F5 key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | Acer Aspire One Netbook 8.9" Notebook
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
A compaq TFT450, can it be used with USB to View?
no USB is not a video cable ever.
i guess you lost the manual, that it?
it tells you what the USB does.
page 2 tells you that is a USB hub, you use it to connect other USB devices, for say pc that has only 1 or 2 USB ports this allows more.
it is not related to VIDEO in any way.
Jun 03, 2017 | Compaq TFT450 14" LCD Monitor
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
My 2 usb ports on my monitor not working
In order for the two USB ports on the monitor to work, the monitor itself has to be connected to your computer via another USB cable with connectors that look like this:
The flat connector goes into an available USB port on your computer, the square one plugs into your monitor. Check if your cable is connected properly or exchange it with another one.
To eliminate that there is something wrong with your "not recognized device", plug this device into another USB port of your computer. The reason to preferably remove the device safely in Windows is that you can loose data if you just unplug it. If it is an external harddrive, it can get damaged, because you interrupt the power and the read/write head can get "stuck". So check this device on another computer or USB port.
If you have any other questions or something is not clear to you, just come back here and leave a comment and I'm happy to help.
Apr 13, 2009 | Computers & Internet
Kid tough digital camera
The camera has to plugged into a usb 1.1 port, it will not work with a usb 2.0 port. Try using the additional usb ports on a monitor or keyboard. Otherwise you will need to use a usb 1.1 Hub.
Jan 02, 2009 | Fisher-Price Kid Tough Digital Camera
I just received a (refurbished) Pavilion Elite m9350f. During setup, I attempted to connect my old VGA monitor. It would only be recognized by using the adapter for the one DVI port. When it was hooked up...
plug monitor into VGA port, start machine, go into the bios settings and load optimised defaults press F10 then reboot, if the problem persists its your graphics card or monitor
Nov 13, 2008 | Computers & Internet
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
Aug 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
USB port does not recognize 1Mb flash drive
try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
May 17, 2008 | ASUS P5P800-VM Motherboard
Sony DELUXEPRO SDM-X82 18.1" LCD Monitor Logo
445 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
