LG 42LC2D 42 in. LCD HDTV Logo
Question about LG 42LC2D 42 in. LCD HDTV
Tv wont respond to remote, remote buttons light up but tv doesnt respond
Posted by wblanden on
  • wblanden Nov 02, 2009
    thanx for your help but it did not not fix the problem
Anonymous
    New Friend:
  • 9 Answers
Is it the factory remote? if it is check to see if something is blocking the sensor on the tv, clean the sensors, if it is a universal remote alot of new tvs have codes that even some of the new universal remotes dont support. if thats the case you will just have to make do.
Posted on Nov 02, 2009
3 Related Answers
Chi Chu
  • 8457 Answers
SOURCE: tv doesnt respond to buttons or remote
Try website 1-800-Remotes Factory Original.To buy the exact remote.Ur old remote it shorted and dead.
Posted on May 15, 2010
Anonymous
  • 255 Answers
SOURCE: plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
Posted on May 28, 2009
Anonymous
SOURCE: Acoustic Solutions LCD26761HDF TV turned
i have the same problem, have you had any joy yet?
Posted on Oct 06, 2010
TV is on but the standby light is off and the buttons on the remote or the set will respond. Any ideas?
If it's a plasma try resetting. There should be a reset button either on the remote or on back of t.v
If not and if you cant acess your tv settings to reset. You can call Sears 24hr helpline and they will connect you to a tech. Who will help you..No it doesnt cost anything. Or get on web and look up a manual for your tv or just type in what its doing and you will possibly find your answer, but I think it just needs resetting and updated.
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Cant change video mode back to tv mode
take ya camera phone turn on the camera take the tv remote and point it to the phone camera lens look in the screen if u see the light from remote flashing as u press video/tv button the button is hence the remote is ok if the remote button is faulty on video it wont flash on screen if so press the tv/av on tv and u are good to go if the tv doesnt respond then the tv programmer ic is mulfunctioning and needs replacement, u may check the memory chip on tv too for mulfunctions
Tv wont change the input on universal remote
Hello
Some sets wont respond to all functions with a universal remote contro. Try to set the remote control to TV with and other code. sometimes it may help you.
Emerson model #lc200em8g wont program with rca model remote rcu600m
Hello
Codes for Emerson TV with RCA- RCU 600 are
..........004, 006, 012, 023
..........024, 025, 026, 027, 028, 029
..........030, 031, 032, 033, 034, 035
..........036, 037, 038, 039, 041, 042
..........043, 044, 046, 047, 123, 124
162, 171, 177, 179, 191, 196, 208
1. Manually turn on the TV.
Find the three digit code for your TV in
the code list below.
2. Press and hold the CODE SEARCH
button until the INDICATOR LIGHT
lights, then release the CODE SEARCH
button.
3. Press and release the TV button (The
INDICATOR LIGHT will blink then
remain lit).
4. Enter the code using the Number
Buttons.
After your code is entered, the
INDICATOR LIGHT will turn off. If the
code is not valid, the INDICATOR
LIGHT will blink. Check the code list
and repeat process.
5. Aim the remote at your TV and press
the ON•OFF button. Your TV should
turn off.
Note: If your TV does not respond, try all the
codes for your brand. If the codes do not
work, or your brand is not listed, try the Code
Search method on page 16.
6. With your TV on, press CH+ (CHANNEL
UP) If the TV responds, no further
programming is required.
OK
1helpful
2answers
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
Plasma tv wont respond to the buttons being pushed on the tv
2answers
My tv dose not turn on
replace the flyback
available from for a great price from
www.electronix.com
Marvin
Marvin
