Casio Cassiopeia BE-300 Pocket PC Logo
Question about Casio Cassiopeia BE-300 Pocket PC
Trying to hook up BE-300 to laptop with vista. Doesn't connect
Posted by benjam2000 on
Anonymous
    New Friend:
  • 11 Answers
Casio Be-300 does not work with Vista Period! There are some programs online that will "reprogram" your devise. Try "eXpod".
Posted on Dec 29, 2009
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
2answers
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
1helpful
Most wanted
try disabling firewall and antivirus softwares.restart your comp and then try.it`s also noticed that vista doesn`t work without security so you have to try enabling security on vista and as well as on xp.
Vista laptop dosent connect to xbox media exdender/media center
u either need both need to be hooked up the same way try putting your laptop to connect trough ethernet cabel
Laptop will not connect to the internet anymore.
are you using wifi connection, I mean wireless connection or you're hooking up to a LAN network or through a modem connection?  If all this connection wouldn't worked out anymore, try reinstalling your Operating System!
I didnt understand the solution for the router not working on vista
Try hitting <Fn> + <F2> keys on keyboard. If that doesn;t work click Start > Run > type devmgmt.msc > check device manager for your wireless adapter properties --- is it working properly?
DRIVER FOR HP LAPTOP WITH VISTA HOME PREMIUM
try to revert back you have solve by own
first thing you must have gprs enabled in your cell phone
after that go to your service center and tell him to give pc suite
2answers
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
3answers
Top Casio Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
