Question about JVC KD-LH7R CD Player
Mercedes-Benz 6 disc CD player # A 203 820 90 89 MODEL # MC 3010 To replace the above with a new player, do I just plug in the two leads from the old changer into the new changer?
Posted by vagntlman1 on
Ben Slimene Aymen
    Habit-Forming:
  • 110 Answers
Plug in the two leads from the old changer into the new changer and do not forget the power source.
Posted on Jan 22, 2010
  • Ben Slimene Aymen
    Ben Slimene Aymen Jan 22, 2010
Car drives for a mile then stops 1984 mercedes 280se
you didn't say if you replaced/cleaned distributor cap might be worth a look and also spraying inside the cap with wd40
Aug 11, 2014 | Mercedes-Benz Norev Mercedes Benz 280 Se...
My mercedes 2007 s 550 cd says cd error after cd is scan
If you take your car to a MB dealer, they can do a test of the CD system. Unfortunately, the few times that I have seen this problem, it has required replacement of the VERY expensive COMAND module.
Feb 01, 2013 | Mercedes-Benz Cars & Trucks
My mercedes s550 cd player scans cd then says dics error
same with my problem .it's mean the eye laser is bad. you can't fix it.i have to go to the ebay buy the use one for $800 dollars. mercedes s550 tech such...too many problem. my is 65.000 mile i already replace lower arms control on 2 side A/C blower fan 2 struts suspension. now is the font lelf window not working. my god. i think the old toyota corola the tech is better then. (S550)
Feb 01, 2013 | 2007 Mercedes-Benz S550 Sedan
When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player indicates that there are discs in all 3 spaces,...
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay
Jul 29, 2011 | Philips MC-70 CD Shelf System
Hi i have a mercades benz clk320 1999 model an the cd changer is comming up as 'magazine empty' how do i go about fixing it??
you dont say if its standard fitted model hifi unit, i take it you have pulled the din plug out of changer unit and checked all the pins are there? push plug fully in, check head unit end too, if thats done i had one that needed resetting on head unit, another the disc unit had dodgy earth lead, they dont norm give up. saying that my dads gave up when he hit a spped hump to fast. tricky...
Jun 14, 2011 | 1999 Mercedes-Benz CLK
I was told that the laser in my 2002 C240 6 disc changer is weak. It came with the car, and its in the glove compartment, I was told its alpine, and it has the mercedes logo on it. I was quoted $200 to fix...
Mercedes has had issues with their cd changers for years. The price they quoted you is not to bad actually as a brand new Mbz cd changer can be a little pricey. If you buy a new one they will ask for your old one as a core so make sure to ask for a reconditioned one. They call it reconditioned because the housings are not brand new but all the interior components are. Your stock cd changer has the connection for the fiber optic wires. If you go with aftermarket you will lose that connection and will not be able to control the cd player from the radio or the steering wheel controls.
Sep 30, 2010 | 2002 Mercedes-Benz C-Class
Glovebox mounted 6cd changer in mercedes slk 350 does not work
If you can pull the player out, I would take the red and yellow wires and twist them together. Then place it on a battery terminal. Red/yellow to positive and black to negative. If the fuse is good in the player, the power should turn on and you can remove the cd's.
Jul 02, 2009 | 2005 Mercedes-Benz Mercedes Benz SLK350
RADIO CODE FOR MERCEDES-BENZ AUDIO 10 CD MODEL: MF2910 S/NO. AL291011169568
Je recherche le code de la radio Mercedes Benz audio 10 cd A 1708200389 Model n° MF 2910 Fabriqué en France S/NO AL 2910 1 0429494 B
May 30, 2009 | 1999 Mercedes-Benz E-Class
No disc
When the Astar PD-3010 or the PD-3020 shows no disk it mean that your DVD laser are defectived. Need resolve this problem? Please call me at 323-767-6030.
Dec 26, 2007 | Astar PD-3010 Portable DVD Player
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
JVC KD-LH7R CD Player Logo
247 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
