Question about Maytag Neptune MDE5500AY Electric Dryer
How do I access the drum of my Maytag Neptune Dryer from the top. One of the inside fins of the dryer has come off and just needs to be screwed back in, but I need to access the top of the dryer drum and I can't get it open.
Posted by pennylw on
A Miller
  • Maytag Master
  • 8,404 Answers
Try to pop the top up on it ... then remove the front. be careful of the wires on the door switch
Posted on Nov 02, 2009
1helpful
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
2helpful
How do I access the drum to tighten the dryer fins
Disconnect power to the dryer !!! Remove the 2 screws holding the door hinges on and remove the 2 screws opposite the door hinges . This will let you pull the top of the front panel outward and lift off the bottom clips . If you have enough room , slide your arm thru the front opening to tighten the screws . Otherwise , remove the 2 screws holding the clips for the top , 1 on each side , and lift the top , to get better access to the screws .
1helpful
Fin inside came off
remove toe kick panel screws by the floor and lift upward on front cover and pull upward to remove like lifting a car hood,then there are screws just inside the bottom side of the top cover,remove these and tip top back and secure top as to not break off electrical connections off control panel,then you can access the screws for the paddle fins to re-secure to the drum,if they're oblong from wear and tear either replace or fill the hole with a cement for this purpose and put in 2 match stick pieces (quickly)before glue sets and this will take up slack and seize paddle screw all in one
1helpful
Remove and replace fins in drum
ok
1. take off the door hinge screws,
2 take off the two opposite the hinge
3. lift the door up and out
4. graqb the slim side walls on either side of the door way
turn them in and pull the whole panal tword you
5. once you have the door cowel off, you should see two top dogs screwed down with 2 5/16
romove those and the dogs
6. with the top dogs off you should be able to lift the top, like the hood of your car
7. once the top is up , you will have access to the tumbler top and the screws for the fins should be right on top
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
41helpful
2answers
FIn inside neptune md55 dryer came loose need to remove side pane
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
7helpful
2answers
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
